BigWoody Posted October 11, 2010 Report Share Posted October 11, 2010 I have quite a few blades that I inherited from my father. I do not know the brand of some because the markings are worn down. Is there a way to tell higher quality blades from lower quality ones just by looking at them? Is it worth it to get the blades sharpened, if so where do I get this done and how much does it usually cost? Quote Link to comment Share on other sites More sharing options...
Craig Posted October 11, 2010 Report Share Posted October 11, 2010 I have quite a few blades that I inherited from my father. I do not know the brand of some because the markings are worn down. Is there a way to tell higher quality blades from lower quality ones just by looking at them? Is it worth it to get the blades sharpened, if so where do I get this done and how much does it usually cost? I'd recommend finding a local sharpening service to help sort thru the blades. They could probably give you a good assesment seeing them first hand. Typically sharpening services charge by the number of teeth and sometimes size of blade, and any repairs required. Quote Link to comment Share on other sites More sharing options...
