Using a tack cloth
This is probably a basic finishing question, but I am wondering if tack cloths actually cause problems.
What is the best way to remove dust when finishing? I have tried a tack cloth but feel they may mess with stain absorbing or finish coats. Is it best to stay away from the tack cloths and use mineral spirits or related products?
Thanks for the help.
For white wood sanding dust:
Shop vac or compressed air to remove the majority of the dust. Then wipe your wood down (wash) with either 50/50 of denatured alcohol and water if using water-based stains / dyes. Or a wipe with mineral spirits, if using oil based stains.
Make sure your wood has had ample time to dry before coating.
For mid-coat sanding dust:
Shop vac or compressed air. Then take a damp cloth with water (more dry than wet) wipe the dust off.
Make sure surface is dry before your next coat.
-Ace-
In theory, yes, the resins in tack cloth could contaminate parts of a surface for finishing. That said, I have personally not had that problem whenever I did clean up with a tack cloth, but not saying it hasn't happened to anyone else. More practically though, tack cloths are just another thing to buy and keep stocked up on when there are many more ways to clean that surface with things you already have on hand.
I never use anything but a quick wipe with medium  3m pro pads and compressed air. The Pro Pads are perfect for between coats much easier than sandpaper. I never wipe down with any chemicals unless it oily wood. Never water unless its to raise the grain for a WB finish. Pro pads are cheap wholesale is only 22 cents each so retail can't be a lot higher.
The only thing we use them for is between first and second coats of floor finish, after screening and vacuuming the first coat-using moisture cure urethane.  Spread several out and push with a push broom-turn and repeat.  It eliminates having to screen between further coats.  I stick with what works, so I've never even tried a water based floor finish, and would probably be scared to tack rag anything different than what we use.
  • 26,009 Total Members
  • Joseph b Newest Member ·
