Color difference after staining between HD and lumber yard maplr
I've been trying to find the right color for a kitchen table top and everyone has suggested doing a sample to get it right.
In my case, my top is mostly Birdseye maple. To test the color, I made a sample color board with lots of different dye concentrations. I made this from a 1x4 from Home Depot . I also put the same concentrations on the end (to be cut off) of one of my Birdseye boards. Underneath both was a conditioner (Charles Neil's). No Blotch which I'm happy to report, but I find the home Depot board to be very much lighter than the samples on the birdseye board.
Can anyone provide an explanation, and more importantly a fix? I will of course test another Birdseye board.
The Birdseye is kiln dried from a lumber yard. Does anyone know if HD maple is also kiln dried? Without stain, the HD board is also somewhat whiter, but I was assuming that the conditioner and dye would even things out.
Help?
Each board came from a different tree. White maple is sapwood . The figured wood is usually darker in my experience ,,it also absorbs stain differently.
Only test on the scraps of the wood you are building with. You can also test on the underside of a tabletop if you are careful.
The basic issue you have is that Maple is not a single species, but a collection of species (about 130) mostly from the genus Acer binned into a group labeled 'Maple'. In North America, there about 20 common species termed 'Maple'... The broad 'Maple' category is sub-divided into Hard Maple and Soft Maple. Again, these are handy bundles to group the individual species...
Birdseye in Maple is [almost always] restricted to the Hard Maples (Sugar/Rock/White or Black). Many retailers selling 'Maple' are selling members of 'Soft Maple' (Silver, Red, Water, etc). Soft Maples are far more prevalent than Hard Maples and cost quite a bit less. If you purchase 'Maple' at a retailer, then you're probably getting a Soft Maple unless it's clearly labeled Hard/Sugar/Black Maple.
In addition to difference in 'hardness', The Hard and Soft Maples take finish quite differently, so it's generally a bad idea to mix Soft and Hard Maple in a single project... It can be done -- Hard Maple top w/ Soft Maple aprons... But Hard and Soft should never be mixed in a glue-up panel...
Unlike the other figured maples, many folks prefer the look of birdseye sans dye/stain/etc... While color can bring-out the figure, it can also bleed into the surrounding area and actually 'dilute' the impact of the eyes... Too add to the confusion, there are generally two categories of birdseye -- white and brown. The white is more highly desired (and significantly more expensive) than brown birdseye. If you are purchasing stock labeled 'birdseye', then it's probably brown birdseye (say $6 - $8/bf). If you are purchasing white birdseye, then it's typically labeled as such -- and about twice as expensive ($12-$18/bf)... While some folks color brown birdseye, very few tint white birdseye -- at $18/bf for fine figured White, folks don't want to hide that. I just finished a bunch of tables in high-figure White and the look is great without any color -- the figure stands on its own...
As stated above, you need to test your finishes on actual off-cuts from the project, not surrogate stock... With a bin as broad as 'Maple', it's just too easy to end-up comparing apples to oranges...
Interesting.  I had assumed that birdseye was soft maple.
I had not intended to make this table out of birdseye, but the yard where I purchased the wood takes the slightly less pronounced curl/birdeye and sells it with the soft maple in the bin next to it.  The plain hard maple is in the other building.
I suppose I am going to have to up my finishing game and figure out how to even out the color.  not being a spray guy, any suggestions?
==> I had assumed that birdseye was soft maple
Most birdseye is found in Sugar (Hard). Some birdseye is found in Red Maple (found mostly on the East Coast). Red is a funny animal -- it's not binned with Sugar/Rock/Black/etc in the Hard Maples, but it's considerably harder than those labeled as 'Soft Maples'. Red is a Soft Maple, but its also a bit of a middle ground. It takes finish about the same as hard maple, but it develops a noticeable tan cast over time, so you shouldn't mix Red and Hard Maple in the same project... It'll look great for about six months...
  • 26,009 Total Members
  • Joseph b Newest Member ·
