XBIGJIMX Posted May 11, 2014 Report Posted May 11, 2014 So anyway I have this Craftsman Drill press I was given, but I already had a floor drill press. So i posted it on Craigs list but after a month no takers what to do with it. Well I was half asleep and the thought popped in my head .."Hey why not make it the buffing station you need". So I said well that a damn fine idea..... So the only thing I bought was the wheels and this from Grizzly After pulling it apart and tossing the extra parts I was left with the motor , pulleys, belt, and stand. So i started off adding some extensions so I would have some clearance from the stand so I don't accidentally bump into what ever i was buffing. So I grabbed some scrap Cherry and Maple. I cut em to the size needed and angled the edges with a hand plane. Now I was really interested int he pulleys because I wanted the ability to adjust speed. Cause when doing finishing slow is always good. Now the first issue was the I.D. was to small to fit the arbor. So I am to cheap to buy the correct size so lets mod this sucker out. To the Lathe! So I bored it out to fit and then drilled out and tapped 3 set screws in the first hub. Next Plugged the countersunk screws with Walnut and added a few coats of Tung Oil. And made a box for the switch out of maple and wired that. Now with everything bolted in. I added the wheels and made some washers/stiffeners out of some end grain cutting board scraps. And boom one professional buffing machine with adjustable speeds Quote
TerryMcK Posted May 11, 2014 Report Posted May 11, 2014 Great use for a defunct drill press. Are you going to devise some sort of guard over the belt? Quote
XBIGJIMX Posted May 11, 2014 Author Report Posted May 11, 2014 You I have not really gave that any thought, but it's not a bad idea. Much better then my hey keep your hand out of the belt idea. Going to have to brain storm on this one. Quote
Tpt life Posted May 11, 2014 Report Posted May 11, 2014 Find an old bike chain guard. The metal will give you a form to work with even if it needs to be modified. Quote
