Jim_ Posted November 20, 2010 Report Posted November 20, 2010 I am spraying with my winriver confertion spay gun for the first time wanted to know if you just have a couple things to spay what do u do inbetween coats do u clean the whole gun or just spray some thinner or something else through it to clean it out Quote
AceHoleInOne Posted November 20, 2010 Report Posted November 20, 2010 First, can you give us more flavor. :) What product or topcoat are you spraying? How soon do you re-coat? -Ace- Quote
Jim_ Posted November 21, 2010 Author Report Posted November 21, 2010 I am talking about water base top coats mostly, I also like to use oil base arm-r-seal from general. I would like to do it all in 1 day Quote
AceHoleInOne Posted November 22, 2010 Report Posted November 22, 2010 Always read the finish manufactures recommendations regarding re-coat times. Finishing all in one day is not possible in certain to most situations. Topcoats, whether oil or water-based need to dry-back some and be smoothed and or scuffed for adhesion of the next coat, especially on mid-coats. For daily use between coats do you clean the gun? I’m not of the mind that a spray gun is a good substitute for storing finish, that’s what paint can’s do! I hear guys talk, they will keep finish in their spray guns for days. My suggestion is DON’T, especially with water-based, heck, any finish for that matter. All it takes is a little hardened finish and your spray gun transforms into a royal pain in the A** Don’t be lazy, clean that gun at the end of each day. BUT, BUT, BUT during the day all you really need to do after a coat is, leave the finish in the cup and toss the aircap in a jar to soak in your cleaner of choice and give the fluid nozzle a good wipe. What to use to Clean a spray gun; Water-based finishes - I like to shoot hot water, then I will shoot some denatured alcohol as final clean. Oil-based finishes – I shoot typically mineral spirits or naphtha, then wash through water, then a final shot with lacquer thinner. That just me and what I do -Ace- Quote
