Outdoor furniture finishing help
Hello fellow woodworkers!
I'm looking to build at least one of these in the very near future. If things go well I hope to build a second one. The article indicates a pre-stain which I can get easily at a local big box store however the stain I can't seem to find locally and even having a hard time finding a good option online. I have found it for about $82/gallon which is a bit higher then I'd like to spend. To protect everything (as it'll be outdoors) the Helmsman Spar Urethane I can get locally but only in quart sized. I found a gallon online at Amazon. I pinged Mark (Wood Whisperer) to ask what he prefers for outdoor projects and he suggested Epifanes. I looked it up and almost fell out of my chair at the cost per gallon (about $250!).
I'd prefer to keep overall costs down, given that the wood/hardware for the tables should run me about $200, at this point the finishing costs will exceed (unless I make a set of two). With that said I'm willing to fork over the extra money for these if I can get a better sense for how much I really need to do what I want. Basically what I'm struggling with is, will a quart of each (pre-stain, stains and spar urethane) be enough to cover two sets of tables?
Also, if I go with Epifanes, will I use less overall because I won't need as many coats? The article suggests three or more coats of spar urethane, would I need to do the same with Epifanes?
Please advise. I want to buy enough to make sure I can do two tables but don't want to buy so much I have a lot left over that ultimately gets wasted. Also, if anyone has some other thoughts on how to finish these tables for outdoor use I'm certainly interested. I absolutely want to go with a walnut stain, that is the only requirement I have.
Thanks,
Kyle
I would agree that helmsman spar would be a good choice and likely best bang for buck in an outdoor setting. I put 3 coats on a large oak outdoor bar top that is 6 years old now and took a lot of abuse. It's just now looking like it can use a scuff and another coat. Gallons of beer, lemon and cherry juice, soda and chlorinated pool water have stricken this top and it held up great.
For an oil you can reapply every year, check out Penofin Marine Oil.  I just did a mahogany outdoor table in it.  It has been out in direct sun and rain for about a month (yeah, I know, not much of an acid test) and still looks good.  It is a compromise between "no finish at all" and 10 coats of spar varnish.  You just reapply when it starts to look a little detoriated.
Right now I am building a larger cherry table that will go on my back deck.  It will mostly be covered by an awning, but will see some sun and rain.  For that table I am using epifanes.  It was $35 for a quart at West Marine.   It is difficult to price compare to box store spar varnish.  The epifanes is very thick... you dilute the first few coats by 50% - 25% with mineral spirits.  You could argue that it works out about the same.... with the cheaper products you are mostly paying for the thinner.   It is easy to apply, but right now it is taking 30 hours to cure enough to buff and recoat.  I just did the second coat this morning, it literally took me 5 minutes to brush a coat on a 48" round table.
I'd avoid any water base products for something that will get exposed to standing water.  My parents have a cedar fence in their backyard.  Half the fence was finished with an Olympic oil finish when you could still get it in 5 gallon buckets.  A year later they built the other half and the oil based stuff was not available in large containers.  So they use the water base product.    7 years later, the part done in oil looks okay.  A little mildew here and there, but it looks acceptably rustic.   It could be powerwashed and recoated with oil and look almost new.  The part done in waterbase look like crap.  The big problem is those products tend to peal rather than just erode away.  Pealing paint/stain looks a whole lot worse than a degraded oil finish.
I know the water/acryclic/latex formulations have improved.  I'd use GF exterior 450 on stuff not exposed to direct UV or standing water.  But once water based film finished degrade, they look like pealing paint.  Which looks like crap.
Edit:  I typed this before Ace linked to the GF products.  I have used their exterior oil but I expect it would be similar to the Penofin oil I mentioned.  I do think GF exterior 450 is a good product and I have used it.  I would be careful about subjecting it to standing water.  In fact, I will probably use it for the base of the table I am currently building - mostly because I prefer to spray than brush it it sprays great.
  • 26,012 Total Members
  • JAR Newest Member ·
