I recently purchased a used 16" planer and if i run two boards simultaneously my rift side sometimes studders.. Like the isn't enough pressure on the right side to feed it through.. But only when i run two boards through.. Any ideas? Is it just the pressure rollers being at wrong? One side down more then the other? Sent from my SGH-I337M using Tapatalk
There are about a dozen newbie questions... But I'll skip those and just assume you waxed/cleaned the beds, checked the bed rollers are raised and uniform (cam/shaft not warn on the right side) and the like... What make/model planer? How are the feed roller cams adjusted (rough stock, planed face, etc)? If you run a wide board, have you checked thickness across the width?
  • Who's Online   2 Members, 0 Anonymous, 72 Guests (See full list)
    32k
    437.5k
    26,007
    FurniCore
    FurniCore
