Is sub-200 RPM drill press speed worth it?
I've got a cheapo  5 speed benchtop Skil drill press that has served me well for a few years now, but now that I'm using bigger forstner bits I'm finding that it's lowest setting, 500 RPM, isn't slow enough.  I've decided to upgrade to a floor model and the 3 that I'm currently considering (HF 13" 16 speed, the Porter Cable 12 speed at Lowes, and the Wen 4225 variable speed) all have a minimum RPM roughly within the same range (220, 300, and 280, respectively).  So assuming I get lucky with the cheaper brands (HF and Wen), the 3 drill presses are roughly equal specs-wise and it comes down to cost.  I do see that Grizzly has a drill press, roughly at the high end of my price range, that also has a 140 RPM setting.
The Skil drill press has been sufficient to meet my current needs for my projects, except for that next step down in RPM speed, the 250 range for the 1"+ size forstner bits I have (2" is my biggest one, currently).  So, how useful is that 140 RPM setting?  I would hate to upgrade to one of the other 3 drill presses, only to find later that I need the capability to go lower than 250 RPM.
I have that Lowes PC drill press. It has ran for roughly 4 years without a hitch so far. I've run 3 1/4" Forster bits no problem with it.
I yanked out the belts and replaced them with link belts - that made a huge difference. Careful to note that the belts are a smaller size than what you can get at Woodcraft for table saws. I think it's 3/8". Had to order them off eBay.
also had to shim the middle pulley up with a couple of washers as it wasn't parallel with the other two.
all things you can expect from a drill press at this price point.
runout has been acceptable with stock chuck.
you will definitely want to make a table for it...
For the $, it has done well for me.
250 RPM should do you... If you need to spin anything requiring a lower RPM, then you need a bigger drill press...
For your reference:
Yeah, that was basically my question.  I have that chart taped up next to my drill press, and saw 250 RPM was the speed for the largest forstner 2" size .  But now, after looking closer, I see multi spur bits go up to 4" and actually look identical to the PC forstner set I have.  I've looked at that chart many times, but completely missed the multi spur bits until now.  Thanks hhh!
Twodeuce, thanks for the info!
For your reference:
Chart doesn't seem to be available any longer... or maybe it's just me :)
