earbogast Posted March 1, 2016 Report Posted March 1, 2016 Just started using my Hegner scrollsaw and wanted to ask if any other Hegner owners have problems blade changing in the bottom blade holder? I have the quick clamp for the top blade holder but it is really a pain in the arse changing the blade in the standard blade holder in the bottom. Last one took me about 20 minutes and it's really frustrating. If anyone has had problems with this, how did you remedy? Maybe it's just me but I'll know if no one else has problems with this. Thanks in advance. Quote
KenMasco Posted March 2, 2016 Report Posted March 2, 2016 Are you using the nut hole (vise?) on the table of the saw to hold your bracket? I never have any trouble with mine. Quote
earbogast Posted March 2, 2016 Author Report Posted March 2, 2016 Yes, I'm using that. Was doing some research and found on a scroll saw workshop by Steve Good where people had problems with the standard blade holders http://stevedgood.com/community/index.php?topic=6303.0 The blade just doesn't catch pushing it about 1/8 inch into the holder like the instructions but if you insert it further, the blade won't center. Quote
earbogast Posted March 12, 2016 Author Report Posted March 12, 2016 Just in case anyone does a search on this later, I finally got the blade in the holder to stick. It was taking me about 20 minutes per blade but then the blade would come loose once I started the machine. Really stupid of me really but there is a screw that goes into the blade holder. The screw will thread in either side of the blade holder but only one side works where the blade holder will clamp the blade. So in short, even though the blade holder has a thread in both sides of the blade holder, you have to screw into the correct side even though both sides look the same. Quote
