Advice on Joinery on First Project
I'm planning my first project which will be a changing pad tray for my soon-to-be born son. Ive been going back and forth over how i should join the sides. As for tooling, Ive got 2 chisels (1/4 &1/2), some clamps, and will soon have a saw. I’d be immensely grateful for the aid of all your experience on which would best balance duribility and difficulty.
Dimensions: 34” L × 16” W × 4” H (1/2” Walnut)
Options:
Miters – Im weary of the duribility of simple miters so perhaps with splines.
Dovetails [preferred method] though having never done em, Im trying to remain realistic.
Mortise & Tenon – is this even advisable with 1/2” stock?
Rabbets – Single or double
Doweled butt joint
I think a finger/ box joint might be achievable and pretty strong. Kind of like a dovetail joint but all straight sides. Increases the glue surface.
They could be 1/2" X 1/2" . Smaller would give more glue surface if you could achieve that kind of accuracy. 1/4" would be great.
By "saw " do you mean a tablesaw ? This would be hard to do by handsaw unless you had a lot of experience.
Nope just a backsaw. Do you think itd be harder than dovetails? Seems like its pretty straight forward.. (says the guy whos never cut a joint in his life)
Try doing some practice corners before you touch the good wood for the changing pad tray. Go look at some videos and see if you think you can hand cut that straight and accurately.
The video suggestion is good no matter which joint you choose.  The finger joints are a little easier than dovetails, but really, if you can cut the finger joint accurately, you can cut dovetails accurately. The hardest part is keeping things stable while marking out the second pair of boards, (either pins or tails you cut one set first) and there are several videos that address ways to do that.  Really, the hardest part is thinking it's hard. Practice on scrap the same size, and go for it.
  • 26,009 Total Members
  • Joseph b Newest Member ·
