JayTalbott Posted December 23, 2010 Report Share Posted December 23, 2010 I thought I saw something like this in a catalog or on a vendor website recently, but I can't find it again... It's a router bit similar to a normal chamfering bit, except where the bearing is beveled to match the cutter, and is above instead of below the cutter. The idea is to use it like a normal pattern bit, but instead of getting a vertical cut, you get a beveled cut. And if you need to rout deeper than the depth of the bit, you can lower the bit and reference off the previously routed beveled surface. The idea is to be able to do a router bowl with angled instead of straight up and down sides. Does such a thing exist (or something close, and for a reasonable price), or am I just dreaming? Quote Link to comment Share on other sites More sharing options...
John Anderson Posted December 23, 2010 Report Share Posted December 23, 2010 this is the closest thing i could find that looks like that, but it is not exact. i hope it helps http://www.eagleamerica.com/product/v133-0802/ea_-_groove_forming Quote Link to comment Share on other sites More sharing options...
