kixnbux Posted September 11, 2016 Report Posted September 11, 2016 My brother is a farrier and I'm remodeling/carpentry. He bought a rikon drill press and it lasted maybe 6 months before falling to pieces in the trailer. I need one in my rig as well. Any idea what holds up in these conditions? Quote
wtnhighlander Posted September 12, 2016 Report Posted September 12, 2016 Do you need floor-standing presses, or will a benchtop model do? I suspect travel wear is what caused the Rikon to self-destruct, rather than actual use. Tools like that aren't really designed to bounce around inside a moving vehicle. If possible, I'd suggest a benchtop model, and build a mounting system for it, that will absorb / dampen the vibration & shock of travel. Quote
kixnbux Posted September 12, 2016 Author Report Posted September 12, 2016 Do you need floor-standing presses, or will a benchtop model do? I suspect travel wear is what caused the Rikon to self-destruct, rather than actual use. Tools like that aren't really designed to bounce around inside a moving vehicle. If possible, I'd suggest a benchtop model, and build a mounting system for it, that will absorb / dampen the vibration & shock of travel. Just a bench top is all we need. That's all the rikon was. Mounted on rubber grommets but still destroyed lol Quote
Tpt life Posted September 12, 2016 Report Posted September 12, 2016 Weak on terminology here... Don't a lot of chucks friction fit a quill or spindle? Is there any wisdom to recommend raising the table tight to the chuck so that risk in that area is dealt with? 1 Quote
wtnhighlander Posted September 12, 2016 Report Posted September 12, 2016 @shaneymack is building a traveling carpentry shop, but I didn't notice a drill press. Maybe he can offer a tip? 1 Quote
kixnbux Posted September 12, 2016 Author Report Posted September 12, 2016 My trailer is a 21' wood shop. The portable bandsaws even work very well mounted but drill presses just aren't built right for it. At least none I've seen Quote
