Reclaimed wood questions
First Id like to say Ive read tons of threads and realize its not everyones cup of tea but don't want to debate that, would just like thought on a few questions. Pretty new to wood projects and its just a hooby for me so sry if any questions seam to simple. This week I was offered a lot of skids from a shop that does fabricating and they are mostly hardwoods with probably 75% oak and then a spattering of other stuff. I took 5 home and cleaned them up to see if I was interested in more and  defiantly am cause it has the look I want.
Question one is I know pallets are stamped HT for heat treat or other stamps for other methods of treatment. I think i read it had to be stamped if it came from out of country (USA). These had no stamps, are made of 2x4 and 3x4 and 3x3. Anyone know how these are generally treated?
Second question involves the cracks. I scrapped any boards that looked to badly cracked and almost all that had bug holes even though I did cross cuts here and there and believe it to be bug free as much as I can. Would love to hear the best way to check but I didnt see any thing trying to follow a few holes of different sizes to the end. I set a few to the side that had a minor amount of holes with no other holes in surrounding pieces because they had really nice grain to them and would like your thought if they are safe to use or how I can be safe. I read were someone took a needle and flushed the holes with mineral spirits. i have some needles from a vet so this would be easy. I also wondered is a runny super glue or epoxy would run in these holes and seal it off and help or if on the small holes it wouldn't be runny enough to go through. If so which one would be best for that and cracks. Id like to do several at once for time and at the local store they only had loctite go2 which didn't seam runny enough to say put saw dust in a bigger one and run through. All other stuff they had only came in half oz.
TY for any thoughts.
Some pallets can be treated with some nasty stuff that I would not really want in my house.  I'm not an expert in knowing how you determine what method of treating was used.
I would use epoxy not super glue. If you look on YouTube you will find methods on how to fill.  In the refinishing of his outdoor table Marc filled defects with epoxy.  I know Cremona and others have similar videos.
2 hours ago, Lester Burnham said:
+100
here's what google turned up
https://www.1001pallets.com/pallet-safety/
Ty for the responses. This is not an argument for or against just telling you what I do so you know I don't take it lightly. Ive already read that article and many others. Half way down it says unstamped are supposed to be domestic and usually one time use and from what I read most domestic is heat treated. So far I have made shelves and pallet flags and the like out of pallets. I only take HT stamped ones and several places local set them out on certain days so I can pick them up that day and they don't sit outside. I only take ones that look newer or like new. Im not looking for things that look like they have set outside for 50 yrs. Im very aware of potential bug problem and do everything I can to negate this and always trying to learn more. Ive also read this article http://www.fao.org/docrep/x5042e/x5042e08.htm so I could be more informed on the effects of MB and how much of a real threat it is. The article was more likely to deter me from eating tomatoes,potatoes and strawberries any more. They are spraying it all over our food apparently. Everything I use gets lightly sanded to take the surface before storing so I can see bug hole and condition to see if I want to keep then when finishing some projects the suface planed down by a electric hand planer (trying to set up a bigger one). If I use the skids all sides would be planed down.
You might ask why do I do it, sounds like more trouble than its worth. I enjoy it. Its a hobby. If I make any money at all it goes to buy tools and sometimes I just make things for people I know for next to nothing just to cover stain sealer and so on. Everything Ive done so far  gets wipe on poly to seal it in case I wasn't through getting it clean but I do my best to. The wood I get just has the look I want, I have no interest in building anything out of plywood or that finished look. If there was a mill or something local that sold the wood the skids are made of so I knew its history and it was reasonable Id buy it. Was looking at the skids because Ive wanted to make some heavy coffee tables and benches for a long time. I in no way typed this to tell you I wasn't considering what you said just so you know where I come from and why Im even looking at it. I agree with a lot of people that there is a lot of junk made out of reclaimed wood and Im trying not to be that guy. Ive also seen some great looking stuff. Sry for the long post and appreciate any one that read it and future thoughts.
Well, the problem with Pallets, as I'm guessing you know, is that they aren't consistent. They aren't made in big factories (well, not all of them at least). A lot still come from small shops with one or two guys nailing these things together out of whatever wood they can find cheap. As a result, you don't know exactly what has been done to them, if anything at all.
Here's an interesting episode of Planet Money that deals with pallets.
As Bryan mentioned, epoxy is best for filling holes. But won't deal with any bugs that are still in your wood, as it is very unlikely the epoxy is going to penetrate fully without a vacuum chamber. The only truly safe way to deal with bugs would be to heat treat the wood, but that's probably not an option. On the few occasions when I've reclaimed wood or furniture, I use a borate spray, then sticker the treated stuff away from anything I care about (this includes exposed wood in structures). You could probably wrap it in plastic to help protect the rest of your wood as well. The borate should kill anything emerging from the wood, and prevent re-infection, but doesn't actually kill anything alive inside the wood. For this reason it's best to wait as long as you're willing, for the infestation to die off. One of the last things you want to see is that little pile of sawdust appear underneath your finished piece.
Justforfun, I don't think people are telling you not to use pallets, I know I wasn't, but if I can't trust the source it would really increase my level of caution.  Plus sometimes when this is a hobby, taking all the time to disassemble, treat for bugs and other issues in dealing with pallets it becomes a time vs. value issue.
I have a huge stack of reclaimed wood, and i will use it, but it is a lot of work when I may get 2-3 hours a week in the shop if lucky.
Well I figure being a hobby is the only way Id be able to do it the way I am. If this was about time vs value Im probably going in the hole :)  One issue here is its not the type of place locally that values handmade stuff enough to pay someone for their time using new wood or reclaimed. I know a local wood shop in another town that really struggles and I don't ever see myself quitting my job to make things. How long do you have to wait for bugs to die off? As I said I have yet to see any-I think most holes in the pallets I take were pre heat treated but I usually throw most away If I see holes. Its just hard when you see one with a nice grain. Up till now all Ive done is read gazzilions of threads about reclaimed but this is the first time for asking questions. I might see if I can track the skids back as I think they are getting it all shipped from the same place  but I thought that might be difficult to ask the factory where they get stuff shipped from then call that place to see where they get the skids from and then call that place to see how or where they are made when anywhere down that line someone on the other end isn't going to care enough to go look it up for me.
As far as the rest of the wood reclaimed wood and pallets is all I have. Im not a shop just doing it for fun mostly. By the way Im also not downing the plywood finished look. You guys make some great stuff. I just know that with my limited tools and knowledge so far if I was to want a refined look id be better off just buying it, just hoping to do something thats little different and in level with my tools and skill.
For filling small cracks and holes, I use FastCAP 2P-10 CA glue (they have thin, medium, thick and gel viscosities).  I typically use medium and thick, along with the activator.  Rarely, though, do I use it on stuff that is meant to have a rustic look as that kinda defeats the purpose, unless it is strictly used to improve structural integrity.
I use a lot of reclaimed wood for the rustic-style signs I make.  The wood typically is from an old deck and is usually cedar, so is safe to be bug free.  I would not be afraid of holes or cracks, provided the cracks don't run all the way thru the board.  If the rustic look is what you are going for, the more minor defects, so much the better.  Here are a few signs I have made with reclaimed cedar decking.
39 minutes ago, BonPacific said:
I like that first sign, I might need one like it.
LOL, I have made a few of that one...some for sale, some for friends/family ;-)
Have a look here at more of them:  https://www.custommade.com/by/woodmonkeystudio/.  I don't post every one I've done, but the majority of them are there.  While I have done a few commissioned furniture jobs on that site, almost everything I've done there has been some type of sign.
TY for the pics. Always like pics of nice things. One of the projects Ive been dying to do but needed the wood is an 2'x4' oak coffee table with 2x4 end grains cut to make a 3.5" thick top in herringbone but want it to look more like 90 deg angles instead of the W look with 3.5"x2.5" legs integrated right into the top. Think I figure little over 200 pc and of course lots of glue. I know this is ambitious for my first glue up thats a project that excites me. Probably will do something smaller first but don't know what. Right now I work a lot but have lots of time off in the winter so trying to set up as much as I can from now till then.
As far as treating for bugs. I use a lot of fou d wood. And I wrap it in seran wrap and let them sit in my garage. I live in indy and the garage gets pretty hot during the day. I let them sit for at least a week to make sure any bugs die. This has worked very well for me so far.
As far as the treatment of wood for pallets. As long as you are using a respirator while sanding you should be fine. And if you are worried about contact absorption, put a coatof shellac or poly on it. So there is a physical barrier between you and the wood. Easy fix
  • 3 weeks later...
