Dust collector ducting question
Hi,
This is a follow-up question to an earlier entry about a Harbor Freight dust collector I am installing.  I picked up the dust collector today.  I am going to add a Thein baffle and was going to add a new 0.5 micron filter bag but now have another idea I'd like to get some opinions on.  I have a diy air handler hanging from my shop ceiling.  I say handler, not filter, because it is simply a squirrel cage blower from an old FHA furnace, in an enclosed box, that sucks in shop air and exhausts it outside through a length of corrugated air duct.   There are no filters on it.
Rather than buying a new filter for the DC it occurred to me that I could just connect the DC  exhaust to the air handler duct via a wye and have it also exhaust outside.   I'm just not sure if there would be any airflow issues.  I think everything would be ok if both units were on at the same time since the DC air flow would be joining the already flowing air from the air handler.   However, if only the DC was on then it would be going into an essentially open ended pipe.  The wye would direct the air flow to the outside but is there a possibility of at least some of the air being directed back into the shop through the front of the air handler?  Attached is a very rough sketch up of the way the airflow would be directed and how the ducts would connect.  The DC would connect a few feet after the air handler.  What do you think?
George
I think you will have back flow from the collector coming back out the box. Even with the box blower running you may have back flow. Furnace blowers generate much less pressure than the collector blower. It depends on the size of duct & the number of elbows downstream from the the wye.
It would be better to have a separate duct from the collector to the outside.
Thanks for the comments. What I will probably do is put a gate in to black off the box to prevent any backflow. What  if I put the wye right at the exhaust point?  The initial plan is to pick up a Dust Right hose from Rockler so I can leave the collector in one spot and move the hose from machine to machine as needed.   Full ducting may follow in the future.
  • 26,009 Total Members
  • Joseph b Newest Member ·
