What's an "adequate" amount of airflow through a spray booth?
Hi all, I'm contemplating building some kind of paint booth in my detached garage. This would be for multiple types of finish... rattle can initially, but in the future solvent-based finishes with an HVLP turbine, and I would also use for wiping or brush finishes. What I have room for is something about 8' x 8' x 10' (ceiling height).
Where I'm getting stuck in my planning is figuring how much fan I'll need. At one end of the spectrum, pro-level booths are recommended to have air speed of 100 fpm past the point where you're spraying. Without getting into a complex analysis, if I just assume straight flow across the booth, 100 fpm x 80 sq ft cross-section gives me 8000 cfm. At the other end, I've seen plenty of forum posts and videos where people are using box fans. Maybe even just a single 20" box fan, sometimes two or three. Not sure what volume of air they move, but drawing or pushing through filters, I'm pretty sure even three of them ain't moving 8000 cfm.
An explosion-proof fan that will pull 8000 cfm (if arranged to pull air from the booth) is pricey. Or more involved, if I get into trying to build one like I saw in a video. What's more, being in Minnesota, I have to think about the air exchange in the garage. The total volume inside is around 6700 cu ft. If I'm exhausting 8000 cfm to the outside, cold air has to make that up, and I'll lose heat very quickly. That's with either a positive- or negative-pressure design.
So, sorry for the long background explanation, but my question comes down to what is realistically needed to get by?  I'm wondering if I should just try a couple of box fans pushing into the booth and see how it goes?
Anyone have an idea of what differences I would notice using the recommended 100 fpm / 8000 cfm versus one or two box fans, versus something in between?
Crashcup I am in MN as well. I have one 14" fan not sure of the CFM with a filter over it as well as a 16x20 hole in the wall to the main shop with filters on both sides of it that will clear my 10x12'x10' tall room very quickly. It will reduce noticeably the temp in the spray room but its not like it sucks all the heat out of the entire shop and the spray room never gets cold but you can definitely tell. Also mine is not explosion proof so I do not spray oil based finishes (only water based) but I do use wipe on oil based finishes regularly.  below are some pics of my set up.
The top filter is for the cold air return the bottom is the cutout to the main shop...and apparently that filter needs to be changed ;)
Main shop side
set up on the exterior wall
This is a 12" 800 cfm Dayton fan from Grainger about $200 the explosion proof 12" version would be 1300 CFM and about $900, an 8000 CFM explosion proof fan would be 30" and cost about $1600 :o
Hi pkinneb, that's quite a nice setup having a separate finishing room! Wish I had the space, but my shop is going to be in the basement, and I don't think the smell will sit well with my wife, so I'm looking to do finishing in the detached garage (this one I have to myself, so no worries about stinking it up).
With your setup, the finishing room exhausts to the outside, and you bring in filtered are from the main shop area?  Then makeup air comes into the main shop just through whatever leakage there is? Or do you crack a door or something to ensure adequate flow?
Now, your room at 10x12x10 is somewhat bigger than what I am envisioning, and your the cfm rating of your fan is 1/10 of the 8000 cfm that would be recommended for my little booth. But you don't have any problems associated with insufficient air flow?  And I'm not even sure what those would be... more overspray settling on the wet finish? But that is encouraging if this works out well for you with that size fan.
I asked this question a while back, and Don (particle board) gave some insight. He is no longer on this board, but is a professional cabinet guy with a load of spraying knowledge. Do a search and you should come across it. I think I asked about setting up a spray booth in the basement.
@AceHoleInOne also offered some good advice, so seek his response as well. Steve ( @wdwerker ) is another excellent resource on this board.
Well I'm no expert but I would think 8000 cfm would suck you right out of my little room LOL. Having said that my set up clears the room and I have never noticed any air flow issues. I never leave the door open, in my opinion that would defeat the purpose of having a separate room. I would not consider this a professional spray booth rather a glorified finishing room but it has worked well for me. As Roger stated some folks on the forum are real experts in the field and I'm sure would be a helpful resource for you.
Saw your post on "Is a basement spray booth a dangerous idea."  Quite an interesting exchange between wdwerker and Ace. I think both of them were approaching it from different angles. One from what pro booths use, and one from what is sufficient to keep the fume concentration down at a safe level.
And that goes right back to my question... for someone who recommends the 100 fpm air velocity in the booth, what would they say the downsides, or deficiencies are if you're short of that? There was some mention of overspray settling on finish that had already flashed off.  That makes sense. But is that the only thing? If so, and I was willing to rub out the finish after to take off the nibs, maybe I'd be okay with less. Others certainly seem to get by with less.
  • 26,012 Total Members
  • JAR Newest Member ·
