Keggers Posted December 10, 2017 Report Share Posted December 10, 2017 I need some help. I'm building another Lego table for yet another granddaughter. I used 3/4" plywood for the top of the table and need to edge band those ugly plywood sides. I'm using iron on edge banding and was wondering if anyone has ever pre-stained the banding and if so was the stain affected by the heat of the iron. In case you're wondering - I've already attached the Lego plates to the top of the plywood and I'm trying to avoid getting the stain on the plates. Thank you for any help you can give. Quote Link to comment Share on other sites More sharing options...
Woodenskye Posted December 10, 2017 Report Share Posted December 10, 2017 Why not switch to solid wood edge banding? I was thinking the same about the iron being an issue after staining. Quote Link to comment Share on other sites More sharing options...
Keggers Posted December 10, 2017 Author Report Share Posted December 10, 2017 11 minutes ago, Woodenskye said: Why not switch to solid wood edge banding? I was thinking the same about the iron being an issue after staining. Bryan, that is certainly an option that I've considered. I still might do solid wood. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted December 10, 2017 Report Share Posted December 10, 2017 I would do a test run on scrap. If you don't have the iron too hot and keep it moving it may work. Staining the loose edgeband might be fun.... 1 Quote Link to comment Share on other sites More sharing options...
Keggers Posted December 10, 2017 Author Report Share Posted December 10, 2017 1 hour ago, wdwerker said: I would do a test run on scrap. If you don't have the iron too hot and keep it moving it may work. Staining the loose edgeband might be fun.... Yes, I've stained a test strip just waiting for it to dry. And staining a long strip should be "interesting." Quote Link to comment Share on other sites More sharing options...
wdwerker Posted December 10, 2017 Report Share Posted December 10, 2017 You are still going to need to stain the edge after trimming the edgeband. Quote Link to comment Share on other sites More sharing options...
Keggers Posted December 11, 2017 Author Report Share Posted December 11, 2017 2 hours ago, wdwerker said: You are still going to need to stain the edge after trimming the edgeband. That's true. I'm still undecided which way to go. Pre - staining the edge band won't be an option. Quote Link to comment Share on other sites More sharing options...
Keggers Posted December 13, 2017 Author Report Share Posted December 13, 2017 I went with the iron on edge banding and put some liberon paste wax on it early this morning. I felt that since I'd made the mistake of already attaching the lego plates to the top the liberon wax was the safest option. I'll post pictures of the finished project tomorrow. Quote Link to comment Share on other sites More sharing options...
