wooddude Posted August 13, 2010 Report Posted August 13, 2010 Hello Everyone, I have a Delta Contractor Saw which is acting weirdly. When I start it up, it powers up and then the breaker on the motor trips afetr 10 or 15 seconds. It seems the motor is very hot to the touch, even without much use. Can anyone make any suggestions or have a smiliar experience? Thank you in advance for any suggestions/help!!! Quote
Frank Speyerer Posted August 13, 2010 Report Posted August 13, 2010 I also have a Delta Contractor Saw which I use on a daily basis and have not had the problems you describe...I wish I could be of more help. Quote
nateswoodworks Posted August 13, 2010 Report Posted August 13, 2010 Have you had you saw long or done any changes lately like a different power cord or plugging it into a different outlet. One possible cause is low votage getting to the motor causing low starting torque and overheating. When a motor first starts up the draw is substantially higher than when under load, it can be from 6 to 8 times higher and this is what causes breakers to pop upon startup. If this isn't the case then I would remove the belt and see if that changes anything, this will isolate the problem to either the motor or something like bad arbor bearings in the saw. If it is something to do with the motor the first thing is to make sure the arbor and pulley spin easily and if so move onto giving it a good cleaning inside and out. If you are still having problems we will figure it out. I am sure others will chime in with suggestions as we go too. This will at least give you a starting point, let us know what you find out. Nate Quote
PaulMarcel Posted August 13, 2010 Report Posted August 13, 2010 Everything Nate said. Nate's comment about it taking more current on startup reminds me that if you are running the saw on an extension cord, you might be chocking it. If it's not a 12ga extension < 50ft long, I'd saw move the saw to plug it in directly and try again (well, let the motor cool first so you don't get a false positive on thermal overload). If you are on an extension, get/try a new one to see what happens. A perfectly good 12ga 25ft extension can become a problem if you damaged the cord somewhere. Further, does the motor still start the same as before? E.g., it doesn't hesitate or take longer than usual? I'm not sure if your saw has a universal motor or an induction motor. Does it have the motor hanging off the back by a pulley? That's an induction motor. If the motor shaft is directly connected to the saw arbor, it's universal (another way: scream like a banshee == universal). Usually the capacitor failing will either not start the motor (so it hums but doesn't move) or it starts very slowly (a failing capacitor). You can replace the capacitor pretty easily; it's in the hump on the motor. Capacitor-start motors also have a centrifugal switch that cuts out the capacitor after it reaches full speed. If that switch is stuck open, you'll start normally, but overheat quickly. If it is stuck closed, the capacitor is out of the circuit and you'll have the problems I explained above about a failing capacitor (it will look like the capacitor is at fault but actually the stuck switch is). The centrifugal switch is normally inside the motor housing (duh, it relies on being flug around by the drive shaft). That's not normally too serviceable. Also, which breaker trips? Most induction motors have a thermal cut-out switch on the motor. Is that popping? Or, is there a current limiter switch on the saw popping (think of the black button on compressors)? Or is the house breaker cutting? Regardless, the heat after 10-15 seconds is an indication of a problem. Quote
wooddude Posted August 14, 2010 Author Report Posted August 14, 2010 Hey all, Thanks for the suggestions. The motor is the kind that hangs from the back and run the blade with a belt. The saw is plugged directly to the outlet which is 20amp so that part is fine. I have done some research and the breaker that trips is the thermal protection circut that is actually on the saw motor. As I said, it seems that the saw is running extremely hot with very light use. From my research, it seems that the repair is equal to the cost of a new motor, which doesnt make much sense to me. I have looked at numerous diagrams of the motor but cant find that particular replacement part anywhere. It is as if you cant replce that specific part but have to replace the entire motor, which would be almost the cost of the entire saw. The saw is only 2 years old so this doesnt make much sense to me. I am going to try one last thing. The blade is a year old and getting dull so maybe this is causing the motor to work harder? I am going to put a brand new blae on and see what that does. Thanks again for all of the help! Nate, what you described sounds like it may it. It starts....the blade spins and then cuts out afetr 10 seconds or so. I hope that doesnt mean the motor is toast!!! Quote
likeke511 Posted March 4, 2012 Report Posted March 4, 2012 i had a similiar problem. it wouod start up but shortly after it would top and blow a fuse. i took it to a motor shop and they said it needed a new start capacitor. cost me 60 bucks parts and labor. Quote
