rainjer Posted November 10, 2019 Report Posted November 10, 2019 I picked up my jointer yesterday. Currently the motor is mounted behind the jointer above the base. With it mounted in this location it stick out about 6" behind the stand. I was hoping to relocate it to below the jointer. To do this I would need to reverse the motor. The pictures attaces are of the motor plate, a wiring diagram inside a cover plate and the wires inside the cover plate. Question 1 - Can this motor be reversed? Question 2 - The ground wire on the power cord was not grounded. how doe I ground this motor? (or do i need to?) Question 3 - I need to replace the power cord. What size cord should i use?. Jeremy Quote
wtnhighlander Posted November 11, 2019 Report Posted November 11, 2019 A3: I suggest using a 12AWG stranded wire cord (type SOOW). That's overkill, especially of you wire it for 240 volts, but there will be no question about power loss through the cord. A2: Attach the ground wire to a case screw or terminal box lid screw, if a designated ground point isn't provided. Scrape away any paint or coating for optimal contact. A1: May require minor surgery inside the motor. Matthias Wandel has a good write-up about reversing single phase induction motors here: https://woodgears.ca/motors/reversing.html Quote
rainjer Posted November 12, 2019 Author Report Posted November 12, 2019 So after doing more research and consult a friend that works on machinery it appears i just need to swap the 2 wires with the blue crimped eyelets in the first picture. That make me very happy that I will be able to move the motor below the the jointer. Jeremy Quote
Popular Post rainjer Posted November 15, 2019 Author Popular Post Report Posted November 15, 2019 Progress.... The jointer was missing one of the jack screw bolts and washer. Found one on eBay for $5. That came today so I got it installed and the tables leveled. Next I need to get the motor mounted and aligned withe machine. 3 Quote
