PaulMarcel Posted March 2, 2011 Report Share Posted March 2, 2011 I'm looking for a down-spiral bit with either 8mm or 1/4" shank. It needs to have an 8mm or 3/8" diameter cutter head. Most likely the most probable is to find an 8mm shank 8mm cutter, but I'm not finding. Any leads? I tried the usual suspects directly. Prefer carbide but HSS will do as well. advThanks!ance Quote Link to comment Share on other sites More sharing options...
kforsythe@gmail.com Posted March 2, 2011 Report Share Posted March 2, 2011 Do you really need the 8mm or 1/4" shank size? You are unlikely to find a spiral bit with the cutter diameter larger than the shank. If you can use a 3/8" or 1/2" shank check out the Freud bits. http://www.amazon.com/Freud-76-105-Diameter-Height-2-Flute/dp/B001J9HC66/ref=sr_1_1?ie=UTF8&s=hi&qid=1299095521&sr=1-1 If you need the 8mm shank check-out Vortex Tools http://www.vortextool.com/index.cfm?fuseaction=product.display&Product_ID=63 http://www.amazon.com/Vortex-VX01322-Downcut-Finishing-Spiral/dp/B000K29RXE/ref=sr_1_2?ie=UTF8&s=industrial&qid=1299095882&sr=8-2 Quote Link to comment Share on other sites More sharing options...
PaulMarcel Posted March 2, 2011 Author Report Share Posted March 2, 2011 Yes, I need either shank size; can't use 3/8" or 1/2" :`( I know it's unusual for the cutter to be larger than the shank, but I thought I'd throw out all the parameters and see what came back. That Vortex is PERFECT! Ordering now! Thanks for the help! Never heard of Vortex before so added to my list of usual suspects I knew a CNC guy would chime in! Quote Link to comment Share on other sites More sharing options...
