Best Wood Chipper, Expert Advice to Choose
I researched the best wood chipper as i wanted something easier to handle yard cleanup and turn branches into mulch without all the back-breaking work. i have been dealing with piles of fallen branches and brush every season that take forever to bag up, and my back and shoulders start hurting just hauling the debris around. i went through reviews from trusted sources like Forbes Vetted, Bob Vila, and Popular Mechanics and after comparing many options these two kept coming up as the top choices:
LawnMaster FD1503 Electric Wood Chipper Shredder 15-Amp 1.8-Inch Cutting Diameter Max 14:1 Reduction
https://amzn.to/3KLi2ql
Earthwise GS70015 15-Amp Garden Corded Electric Chipper, Collection Bin
https://amzn.to/4aZ0mlw
however, i am having trouble deciding which one would be better for me and i would love to get your expert advice and hoping maybe some fellow homeowners or landscaping pros on this forum can also share their advice.
i usually chip up branches from pruning trees and clearing storm debris in my yard and need something reliable, easy to move around, and powerful enough to handle limbs up to a few inches thick. Any suggestions or advice would be appreciated.
Thanks in advance
I can't speak to the type of yard waste you are dealing with,but those 15 amp electric chippers wouldn't make a dent in the sort of tree branches I have to eliminate. Should be ok for mulching leaves, grass, and shrubbery clippings, though. Anything more than that will likely require a gasoline-engine chipper.
Keep in mind that a corded electric chipper still requires you to transport the waste to the machine, as its location is limited by the cord, and a long extension cord of sufficient size to carry 15 or more amps without significant voltage drop is going to set you back almost as much as the chippers you listed.
That’s a fair point—and you’re right that gas chippers are better for large, thick hardwood branches. That said, for most homeowners dealing with seasonal pruning, storm debris, and routine yard cleanup, these 15-amp electric models actually hit a sweet spot.
If you’re mainly chipping small-to-medium limbs, twigs, and brush, both the LawnMaster FD1503 and Earthwise GS70015 handle that without the noise, fumes, maintenance, or storage hassles of gas units. They’re lighter, easier to move around the yard, start instantly, and cost far less overall.
The cord limitation is real, but with a proper heavy-duty extension cord, it’s a non-issue for most residential yards—and still cheaper than stepping up to gas. For anyone who wants clean, quiet, low-effort mulching instead of wrestling branches into bags, these are very practical choices
Curious to hear if other homeowners here switched from gas to electric and never looked back.
I’d never buy one on my current lots. All the rental stores around me would rent for my needs. By the time I owned a lot that might benefit, I want it to operate when there is no power close or available. That’s the way it was growing up, so that is my experience. A small enough lot for an electric model, is too small to store one.
  • Who's Online   2 Members, 0 Anonymous, 40 Guests (See full list)
    32k
    437.5k
    26,007
    FurniCore
    FurniCore
