Hi. I have a series of crosscut saws that I need to sharpen and I have some doubts about the process itself and angle questions.
First of all I have 2 saws on which I might be interested in changing the rake and fleam they have, because needless to say, I don't know with what angles their previous owner sharpened them. How should I do this? Do I just start filing with the angles I want until the teeth are shiny and the new angles have been established or should I do it in gentle passes, do the whole saw and repeat the process to do it little by little?
On the other hand, another of the saws I want to sharpen has its teeth filed down, so I'm starting from 0. I filed them because I wanted to change the PPI of the saw. How should I start with this? Do I file across as if I were going to sharpen a ripsaw (but with a higher rake) to form the tooth and when they are all formed I do the same but introducing the fleam? I can't find information on how to do this process, everything points to how to convert a rip to crosscut, how to make teeth for a ripsaw from 0 by filing them again, but nothing about how to file new teeth on a crosscut saw.
By the way, what about the slope? Blackburntools tools has an article about this applied to crosscut saws and the point slope, but I don't know if I should introduce it or to what degree. My initial idea was not to complicate things and not introduce slope to make it simpler, but I would like to know your experience, because I also have some doubts about what rake and fleam I should use on my saws or how important is the point slope. One will be 6 PPI, another 8 PPI and the third I don't know yet, maybe 7 or 9. On my ripsaws I like them to be aggressive, so they have a 3º rake, except for the 4 1/2 PPI one which is 7º rake, but maybe I'll end up changing it to 5 or 3. Should I use the same angles on my crosscut saws or relax the rake and fleam the higher the PPI? I understand that maybe 6 PPI is aggressive on a crosscut saw, but my idea was to resort to it when I have to split thick rough planks. I always work with hardwoods. What is your experience with the angles and what results and sensations do they offer?
On 10/21/2026 at 1:12 PM, Ron Swanson Jr. said:
I recommend this book here:
https://lostartpress.com/collections/all-books-1/products/set-file-a-practical-guide-to-saw-sharpening
I'm not sure if it's available in a digital format or just in print.
It's available in PDF for 17 dollars yes, I also thought it was a physical book. I could buy it, but the truth is that when I have to read or study such long documents in English it is more costly for me since it's not my native language. Maybe Claude can translate it for me. Even so I still have the doubt about the experience and sensation that the different angles offer you, that would help me decide a little more.
So the answer is "it depends" but most of the time fleam on a crosscut cut saw is between 20-30°. It's a balance between crispiness of cut, and longevity of sharpness and durability of the tooth.
I have 2 crosscut saws and file them both at 25° which seems to work pretty well.
Well, I bought the PDF, but I'm going to have to translate it by hand or read it in English. Maybe it's the right thing to do and it will help me practice it.
The easy way to remember the rake on crosscut teeth is to just keep the top of the triangular file flat-horizontal, parallel with a level floor you're standing on.
I like 0 degrees on a rip saw, but to start it I back up over a corner until there is a flat long enough for two or three teeth to hit at the same time.
Don't try to get too creative with changing rake to start with.  Sharp any kind of way will cut better than dull.
I have strips of plywood that I lay behind the saw I'm filing with different angles on each.  You can see pretty easily when the file is with the Sharpie angled lines and when it's off the least bit.
Especially when learning, joint the teeth every time and only take half of the jointed flats on each side.  In other words, leave half the flats on the first side and stop when the rest of the flat is gone on the other side.
Once you get comfortable using standard angles, and get used to using a sharp saw, then you can start experimenting with different angles.
I sharpen with one hand, starting the file in each gullet on the little smooth end of the file.  I don't add anything else to a file but a handle.  The Oregon chainsaw filing handles fit my hand perfectly.  I buy them by the dozen and keep a handle on each size file I use.
To start with, when you are just developing a feel for files, find a cardboard box like a shoe box and use it to lay a white sheet of paper right behind the saw, just low enough to stay out of the way of the filing process.  Notice how different pressures on the file throw different amounts of filings onto the paper.  If a file is not throwing shavings, maybe that file is done.  Find the pressure that throws a nice amount of shavings without having to press down so hard and use that pressure.
Count strokes until you develop a feel for how many strokes do what.  I tried watching youtube videos, but every one just freaked me out.  Every one I saw shows the person going really slow and only using a few inches of a file.  I buy full length files and use the whole length.
I also set a light so it reflects off a freshly sharpened tooth face back at me so I can spot the next one in line quickly and easily.
This is all you need, right here, and free:
https://www.vintagesaws.com/library/primer/sharp.html
  • Who's Online   2 Members, 0 Anonymous, 48 Guests (See full list)
    26,008
    Bob44
    Bob44
