Need help! Watch Danish oil!
Can I sand in the danish oil to help fill the pores?
I have a solid oak top I'm making a coffe table with, I plan on using wipe on Polly and sanding each coat. But can I do the same with the Danish oil the start filling from the beginning?
I often wet sand my projects after the first coat of Danish Oil for just this reason. I've seen Marc do it too, but I can't remember which video/project. I usually use some 600 grit wet/dry paper on the wet surface first using a tight circular pattern and then going carefully with the grain for a few strokes. Let that sit as you would a normal first coat of Danish Oil and then wipe off...
That's what I was thinking. If I do my first wet coat at 320 think it will be ok. I will be following up with the top Coates at 600, 800 an 1000 for the final. It's my normal finish but u usually only do with the wipe on Polly.
  • 26,009 Total Members
  • Joseph b Newest Member ·
