I have been researching bench top jointers and see that a lot of people recommend buying bigger because inevetably most woodworkers upgrade. One common concern is the limited size of boards that can be jointed. Has anyone built extended infeed and outfeed extentions to increase the length of board you can flatten or is this a bad idea?
While you could build extensions to the benchtop jointer, you are then taking up as much space as you would with a floor model, except it is on your bench. ANother thing is that these would most likely be removeable because people move their benchtop jointers because they dont have the space for a regualr jointer, or they just dont have the need to joint large pieces. One thing that I have found is that jointers are one of those tools that require precise tolerences to stay accurate. While it could be done, I think that it would be more of a pain than it is worth. And the last thing is power, benchtop jointer are.... well.... pretty weak. If you are goingto be doing bigger boards, you might as well get something that can handle it. What it comes down to is you are probably just better off getting a floor model than a benchtop if you are in it for the long run. Hope this helps.
I was afraid you would say that, It is going to be a while before I can get a good jointer. I have a Ryobi planer, but I feel like I am at a point in woodworking where I need to start working lumber rather than buying it from big box stores. I guess its time to start saving.
StrangeR, if you have a planer you could investigate the use of a planer sled for face jointing rough lumber. The basic idea is to use a sled to support the material (so it does not flex under the pressure of the planer) and provide a flat reference, so that the planer will create a parallel flat surface. Then you just flip the board over and use the planer normally.
you can also edge-joint with a planer, by running the board through on edge (properly supported).
  • Who's Online   2 Members, 0 Anonymous, 50 Guests (See full list)
