Greg Berry Posted February 7, 2012 Report Posted February 7, 2012 Any suggestions on a blade for this saw? Table Saw There's alot wrong with this saw, can't figure out a safe way to make a zero clearance plate, arbor to small for dado stack (so I've read) back to the plate issue again, fence stinks, miter slots not standard size for aftermarket upgrades etc etc. It's an okay beginner saw but I find myself dreaming of a hybrid hopefully within a year! The wife did good on this Christmas present when I started out but it's like your first car...it get's you from point a to point b but leaves no joy in the middle. No break downs yet but alot of burn marks on some soft maple last week! I've tried adjusting the blade alignment etc but it didn't help, maybe I'm doing it wrong. Quote
Dave's Not Here Posted February 7, 2012 Report Posted February 7, 2012 Burn marks could be caused by a misaligned blade, improper feed rate, dull blade or a totally incorrect choice of blade for the job at hand. You stated you adjusted alignment so you can eliminate that as a cause. Feed rate could be the culprit but usually is more a part of the problem then the problem itself. If you're using the blade that came with that saw then I'd say that probably is where your problem is. OEM blades typically aren't of very high quality. With a mid price range Freud 50T combination blade you would probably see a big difference in the quality of your cuts. Also, if you're using a high tooth count blade to rip then that could also be a reason why you're seeing burning. Quote
Greg Berry Posted February 7, 2012 Author Report Posted February 7, 2012 Burn marks could be caused by a misaligned blade, improper feed rate, dull blade or a totally incorrect choice of blade for the job at hand. You stated you adjusted alignment so you can eliminate that as a cause. Feed rate could be the culprit but usually is more a part of the problem then the problem itself. If you're using the blade that came with that saw then I'd say that probably is where your problem is. OEM blades typically aren't of very high quality. With a mid price range Freud 50T combination blade you would probably see a big difference in the quality of your cuts. Also, if you're using a high tooth count blade to rip then that could also be a reason why you're seeing burning. Yes it's the OEM blade and I figured that is the culprit. I've adjusted what I can without calipers etc since most calipers sit in the miter slot and mine is not a standard size. Any suggestions on the best way to align it without the calipers? Quote
Beechwood Chip Posted February 8, 2012 Report Posted February 8, 2012 Marc has some techniques for aligning the blade without calipers in this video. I'd recommend the Freud D1040A Diablo 10-Inch 40-Tooth ATB General Purpose Saw Blade. You can buy it on Amazon - please use this link to support this forum. [EDIT: For this saw I'd recommend a thin kerf blade, but I forgot to check when I searched. This is what I use: Freud LU83R010 10-Inch 50 Tooth ATB Thin Kerf Combination Saw Blade. I also have a Freud rip blade, but most of the time the general purpose blade is fine for me. I have a Freud 12" 60 tooth LU83R012 on my CMS for cross cuts.] Quote
knotscott Posted February 8, 2012 Report Posted February 8, 2012 I'd stick with something simple, decent quality, thin kerf, and affordable for you situation. The German made Onsrud blades on Ebay are going to be tough bargains to beat right now. The regular pricing on the Freud Diablo, DeWalt Precision Trim, and CMT ITK Plus lines are also very good for very good blades. Quote
thewoodninja Posted February 8, 2012 Report Posted February 8, 2012 Before buying my Jet hybrid saw, I too had a Craftsman contractor saw. I personally found that it was worth the extra money to buy 2 good quality blades. I would suggest a good quality ripping blade and a separate good quality cross cut blade (probably 80 tooth). If you don't have a miter saw, or you do quite a bit of cross cutting on your table saw, then substitute the cross cut blade for a general purpose blade. Either way, make sure to switch over to the ripping blade when making rips. I really think it will help with a lot of your problems. Quote
Beechwood Chip Posted February 8, 2012 Report Posted February 8, 2012 I edited my previous post because I forgot to check that the blade was thin kerf, and accidentally recommended a full kerf blade. Quote
