I bought a saw of craigslist a while back. Thought i got a pretty good deal on what i thought was a decent quality saw. My problem is I havent been able to get the blade set to 0 or 90 degrees with the table. My saw stops tilting back to 0 at 8.7 degrees to the right.. I cant get it go all the way. In my fiddling with it. ( didnt apply much pressure) the stop broke off the trunnion... without the stop there i still cant wheel the saw to 0.
It looks to me that this is all set up in the factory. Are there any adjustments in the saw so i can the blade at a 90 with the top?! Also is it safe to run the saw without that stop or will i need to buy and try and install a new trunnion?
I have an earlier version of the same saw. The stops are adjustable and the trunion is made of cast iron so I can see how it might have broke if your forced it hard enough. Have you looked inside to see what's keeping it from adjusting to 0? Is it rust on the gears? Maybe sawdust packed in there? Before you buy a new trunion assembly I would take it all apart and clean and oil it. Then put it all back together. If it still doesn't go to 0 I would either buy a new trunion assembly or buy a different saw on Craigslist. How much did you pay for it? And does it have the 60" table?
HUH.. Thanks Will for the reply. My though is that the guy before me stressed the crap outta that joint as well, i didn't think i put a ton of pressure on it. Maybe its something a little JB weld can fix? ive never used JB weld on a cast part
I read somewhere to try greasing the trunnion, similar to what you suggest. Say it all works after greasing and i can get the saw to 0, will i NEED a stop on my saw? Is it dangerous?
I paid 400 for the saw, I felt it was a fair price for a saw in my area. a few weeks back i noticed one like mine with cast extensions and 50 inchs to the right come up for 350. I also Found a 3 horse Jet cabinet saw pop up for 275 with a Biesemeyer fence! So i dont think i got that smokin of a deal...
There has to be something holding it from going to 90. Grab a flashlight and start investigating. After you find the problem I would go through the whole saw and tune it up. It will not only get it in tip top shap but let you become fimilair with the saw. As for the stop, as long as it didn't crack or wreck anything else you can still go without a stop. I always check mine everytime when I return it to 90 after I make a bevel cut anyways, sawdust or hand pressure can bring you a hair off square pretty quickly. Get a good square or angle cube and your set once you get your problem figured out. I had that the older version of that saw for many years and it always treated me very well, if not for a smokin deal on a cabinet saw I would happily have it. Let us know what you find to be the problem.
I got into it a little more. Found that there was enough junk built up in the gears that it didn't want to move any further. Took some brake cleaner and a copper brush to both the gears to clean them off wiped them down and re-lubed with wax. The saw works again like a champ. Stoked to get back in the shop to a working table saw. Thanks everyone for the responses and helping me figure this out.
  • Who's Online   2 Members, 0 Anonymous, 50 Guests (See full list)
