I've been working on an old saw for awhile now trying to file the teeth for rip cutting. That's how they were originally filed so there's probably not much else to worry about. I use a magnifier to check on the teeth and they all look sharp to me and they've all been set. By 'Set' I mean I put a saw set on them and squeezed the handle. I've never done this before so I suppose that could be messed up somehow.
Anyway, it still doesn't cut as quickly as my professionally-sharpened crosscut saw. In an earlier post, I got the impression that it should rip as fast as the X-cut did its thing.
Any advice as to what I can check?
What rake angle? How many PPI? How thick is the wood? What PPI is the crosscut? What rake angle is the crosscut? All this will have an impact on cutting speed of the rip vs. the crosscut. The two are typically close in speed if their individual setups are both optimized for the thickness and type of wood being sawn. While sharpening both kinds of saws is relatively easy, dialing in the optimum setup for the best performance is often a bit more challenging. It often takes a good bit of experimentation.
My rip saw has 7 PPI and I chose a rake angle of 6 deg. Not sure what my X-cut saw is filed to. Anyway...
I went back and did some homework. I got out my reading glasses (ahem) and a better magnifier and I realized that I just hadn't finished sharpening before. There were many teeth that were flat or dull across the tip so I filed the whole thing again.
It cuts much better now. You know... now that it's actually sharp. I need to practice this more so I can get more consistent at it.
  • Who's Online   3 Members, 0 Anonymous, 58 Guests (See full list)
    26,008
    Bob44
    Bob44
