My maple butcher block top warped and cracked
Morning. I have a problem with a 36"x48" maple butcher block countertop that has a few cracks and less then a 1/4' warp to it. I found this countertop workbench at an auction for $60. I bought it and loaded it up in the truck, which is when my grievous error occurred. I left the top in the back of my campershell for a day and it began to crack and warp. Yes I know better and I am kicking myself for the delay. Either way I brought it in the house and began to rehydrate it with a humidifier and a spray bottle which reduced the cracks by about half the size (less than 1/32"). The cracks are only on one side along the the upper portion (top) of the end and only partial in depth due to the warp. I plan on injecting glue via a syringe and clamping the top in both the horizontal and vertical planes as shown in http://www.thewoodwhisperer.com/videos/cutting-board-disaster/. Now here is where the suggestions are welcome. Does anyone see anything that can I can change to improve my results or change the process? Thank you
Donut, what are you going to use this for? Is it going to be another countertop or are you planning on using it in your shop. I think the plan of attack is ok, as far as the cracks go,but you may need to do some flattening once the wood is aclimated. Make sure that you seal both sides of the top once you are done. The average butcher block counter top is only sealed on the top side, so it is a disaster waiting to happen.
I am going to use it as the countertop for a movable island. I have been wanting to make a flattening jig for my router so this will be the perfect excuse. Thanks for the suggestion. The whole top was coated with Durakryl 102 which was in pretty bad shape on the top. The bottom finish was still in primo shape but there were enough flaws that I did not want to deal with them. So I hit the top with a sander just enough to remove the finish to allow for the water to penetrate. I was thinking about trying to use a little caul pressure to ease the table flat. How much curvature do cauls generally have over 36"?
That will really depend on how much pressure you put on it with your clamps. I don't know that clamping it down will help though. I saw an interesting video on one of the woodworking sites on how to straighten our a warped table top, but for the life of me I can't remember what they did or who it was that did it. I do remember being impressed though. LOLOL
Would like to see some pics :rolleyes: I'm not sure if this is what you meant by 'glue' but I personally would use a clear epoxy. Let the top acclimate to the house for a few days and let it move however it's going to move then flatten and re-seal both faces and all edges. During the acclimation process it may help to have it clamped in some fashion to minimize cupping. Once re-sealed it should be pretty stable. Couple of Q's.. How thick is the top? and how is the top attached to the base?
