Water Based Wiping Varnish
If one can cut oil based polyurethane with mineral spirits (1:1) to make a wiping varnish, can water based poly be turned into wiping varnish by mixing equal parts water and finish?
That's a good question. I wonder why? It is water borne varnish, and I've thinned it with 10% and 20% demineralised water with no ill effects. I admit that I haven't gone to 50% because I'd read so many '"can't be done" threads. I'll be using it again soon, so I'll probably do a little experimenting. Even at 10%-20% it wiped on beautifully.
Hopefully Hobomonk will chip in and explain chemically if I was just lucky or not...
John
I've read mixed review on applying water borne finishes as wipe on. Common complaint seems to be it dries too quickly so you get streaking.
Solvent is glycol ethers which are then mixed with water which is why you can't dilute beyond 15 to 20%. Solvent based can be diluted almost unlimited using the primary solvent (mineral spririts, laquer thinner, alcohol, etc.).
I have sprayed water borne finish with no problem (so far :) ).
Thanks for thr replies guys. I watched Marc's Podcast on this, and it helped explain to me how the water bourne finishes work. I didn't realize they still included a solvent base.
I wonder how they make the wipe on polyurethane that is sold in California (and other states that don't like oil based wipe on finish).
I have also read mixed reviews on water bourne wipe on finishes. I guess I'll stick to the oil based wipe on.
We are aloud to have them here in California. It's just a pain in the ass for stores to get them cause they have to jump through all kinds of hoops.
Some that I've used limit dilution to 5%, but they come ready to spray.
Suggestion... Don't lump ALL waterbased finishes into the same bucket, TRY some of the General Finishes, ML Campbell, or Target examples. Water based finishes are one place where home centers don't carry the same quality materials as a specialty supplier, and there can be significant quality differences between brands.
General Finishes Enduro goes on with a foam brush as foolproof as an oil-based wiping varnish, and is available from many of the usual suspect woodworking suppliers.
I've also used Zar waterbased polyurethane on faux finishes, and it's fantastically easy to get good results. Zar sells this in a wipe-on formula, if you're really stuck on wipe-on application. My local home centers don't carry Zar, but one local paint store does.
The key to hand applying most waterbased finishes is to get it on and move on... Don't continue to wipe or brush it. Let the finish level, and realize that it may look crappy as the finish "coalesces" as it cures. These finishes dry quickly, additional water often makes them dry MORE quickly, which is why you don't want to overbrush them.
Thanks Barry. I always appreciate your informative replies.
I have mixed and sprayed equal parts of General Finishes water-based High Performance topcoat with water for blotch control and have no issues. Same goes for the General Finishes water-based lacquer. I would not recommend doing so to build a finish. The chemistry is just not there and probably have a very soft finish.
In the past, i used General Finishes Wood Turners Finish as a wipe on. It's a very thin water-based for wood turnings. However, it was on small bowls and worked great. Not sure how that would work on larger surfaces such as a table....I have never tried it!
This is an interesting topic. Perhaps at some point the finish manufactures will address this subject and have a thin wiping type finish??? But a need really has to exist first?
-Ace-
That's really interesting...
It works well? Simply 50/50 with water?
Anytime I can use an in-stock product vs. adding yet another can to my shelf, I'm a happy guy.
  • 1 year later...
So you could possibly dilute it with a glycol ether/water mixture?
  • 26,009 Total Members
  • Joseph b Newest Member ·
