Questions about building a Moxon vise with BC hardware
I am finally seeing the light about building my own tools. One of the first things I want to do when I'm able to get back to the workshop is do a moxon vise with the BC hardware. I have some questions about doing it...
1. It looks like the plans call for 8/4 Maple; what other woods would be a good choice (in case I want to make it pretty)? I'm guessing it would need something hard and straight grained.
2. To make sure I've got the tools I need (since I have so few), besides saws to get the stock to the right size:
a) a 3/4 inch bit
B) a chisel to chop out the nut mortice - what size would I need to make it hexagonal?
3) What sort of joinery connects the two pieces on the back?
I made mine out of Ash and could not be more pleased, as a matter of fact after using it for my roubo and moxon I plan on using it a lot more. It is a little dense and hard on the sharp things but to me it behaves predictable in tooling compared to some of the others that I have worked with. The thing that I am most impressed by is how stable it has been again compared to other woods that are sitting in my shop even when I mill pieces that are quite thin such as the Christmas presents that I made over the past couple of weeks. Beauty is in the eye of the beholder but I think ash is absolutely beautiful if the right pieces are picked and I personally like it more then maple, but then again there really is not a wood that I don't find beautiful. Regarding the hexagon mortise a 3/4 chisel will work perfect. The back clamp base is simply glued on to your back jaw at the base...that simple.
  • 4 weeks later...
Have you gotten to your Moxon yet?
If so, what did you use and how did it turn out?
I used ash. I am not particularly fond of working with it, but good bang for the buck for items such as this and my workbench. Easy to find thick, straight grained material.
I am sure Maple would be fine.
Yes, clamp base is just glued in place. Lots of good glue surface, so joinery not required in this instance.
Nice aspect to the Moxon is that after buying the BC hardware, you can easily make another, should your tastes in wood change. Or you could have several lengths made up and swap out the hardware in a few moments if you desired.
I built a moxon vise using BC design which is detailed on their website, but I didn't use their hardware. I went to Enco ( Google them) and purchased two unfinished 5" handwheels. I then drilled, on my drill press, holes centered in the handwheel large enough to accommadate a 3/4 inch Acme threaded rod. I drilled the holes a little larger than 3/4". I drilled the holes in steps, smaller to larger until I reached the needed size. Cast iron is pretty soft so drilling holes wasn't bad. I used a cheap Harbor Freight Silver and Deming drill bit set for this, that I already had. Next, I had a friend of mine weld( silver soder) some matching Acme nuts on the back side of the wheel centered over the whole, of course.Matching . I purchased all the matching Acme nuts, washers, handwheels and rod needed as detailed on the BC site form Enco, which brought me to around $60.00, which is about half what the BC hardware costs. My Moxon vise turned out very nice and I got free leather to line the jaws from a freind as well . I think the way I did the handwheel is actually a better set up than the one on the BC site, because having those Acme nuts on the back of the handwheels brings the wheels out a little further from the jaws , which gives you a little more room to crank the wheels. This set up may not look as finely finnished as theirs but it certainly works fantastic , I saved money and had fun making it. So there you have it !
