Heat resistant finishes (for a trivet)
I completed a trivet that I will be giving to my sister for Christmas. I am stuck on choosing a finish. I've gotten a few recommendations stating I should use either mineral oil, Tung oil, or BLO. I'd rather not use any of them as I am looking for something more durable, and I wouldn't mind a bit of gloss. My sister will never re-apply finish as needed. Is there any kind of finish that is more durable (poly, lacquer, etc) that I could use? Ideally I'd be spraying it and wiping or brushing would be a nightmare.
Any film forming finish will suffer under high heat. Oil finishes that are built up to a sheen will suffer as well. An oil finish that is dull and in the wood( as opposed to on the surface) is the easiest to renew/ repair.
A lot of trivets have a tile surface that is slightly raised above any wood trim.
Not what I wanted to hear, but that make sense and confirmed my suspicions. With that said, would a non drying oil (linseed oil; not BLO or mineral oil) hold any advantages to a drying oil?
Mineral oil doesn't dry either. Drying oils polymerize , the resin sets with oxygen and hardens.
Sand the wood ,especially the end grain, to whatever grit you think is smooth enough and then use some mineral oil. Always wipe off the excess. Give her a bottle of the mineral oil. Drug stores sell the same stuff for less money, no need for specially labeled cutting board oil.
I think it will depend on what you are considering "high heat". I would think a Trivet would see heat in the range of ~500 F at a max.
Poly can withstand heat up to ~450 degree F for a short period of time. I don't know if that helps.
Here is a link to another disccussion thread on the issue. One poster claims BLO works. I have just used mineral oil. Not the prettiest, but they have been functional for 3-4 years without any signs of burn or wear.
Here's another vote for mineral oil. Never had a problem with it for that type of application.
Like Steve said, anything that forms a film with not survive long.
I decided to go with a non-drying oil. Since I have a ton of mineral oil for cutting boards, I just used that. I sanded it down to 400, and the end grain down to 800. I always use the drug store stuff. I can't believe GF sells mineral oil for ELEVEN DOLLARS!. I have 2 bottles, one mixed with beeswax, obviously I am going to skip that one.
Once the final coat is dry, if I burnish it with craft paper, will it gloss up a bit?
Just an FYI. I went to a CVS drugstore to buy some mineral oil. They were charging @4.50 for a pint. I went next door to one of those dollar stores and bought it for 1.25.
