need help asap..
hi there
doing a 55 piece cabinet job...maple...stripping existing urethane off (has old coat of honey stain on under urethane)
customer chose dark brown and gave me spec to buy stain and do sample
i stripped one door..took off urethane and sanded...left the old honey stain in tact. two applications of waterborn brown stain by brush...(no conditioner)....wiped off stain both times...brushed on 3 coats of latex clear satin varathane...showed customer sample....she loved it....therefore got the go ahead for 55 pieces.
question: should i continue to *not* condition the remaining pieces?...sample piece not blotch...but almost...if that makes sense.
question #2) my apprentice sanded s a few cabinets right down to bare maple...sanded out entirely the honey stain left from previous application....so these 3 cabinets...(center panel) are the odd guy out....should i restain these panels honey....*then* switch to dark brown...so that the starting point is the same for all pieces or should i just hit the bare white maple center panels with the dark brown an extra time (3 coats)?
hope that all made sense...thanks in advance..
evets
hi there
doing a 55 piece cabinet job...maple...stripping existing urathane off (has old coat of honey stain on under urathane)
i stripped one door..took off urathane and sanded...left the old honey stain in tact. two applications of waterborn brown stain by brush...(no conditioner)....wiped off stain both times...brushed on 3 coats of latex clear satin varathane...showed customer sample....she loved it....therefore got the go ahead for 55 pieces.
question #2) my apprentice sanded s a few cabinets right down to bare maple...sanded out entirely the honey stain left from previous application....so these 3 cabinets...(cener panel) are the odd guy out....should i restain these panels honey....*then* switch to dark brown...so that the starting point is the same for all pieces or should i just hit the bare white maple center panels with the dark brown an extra time (3 coats)?
evets
couple of other questions:
the dark brown stain was waterborne....i noticed that when i was starting to wipe it off almost immediately after having brushed some onto a cabinet...that it already started to set up (dry)...and wiping it down was almost not working.....should i switch to oil based stain for this? also...i envision spraying the stain first then wiping it down (55 pieces both sides)....smart idea or should i being using gel and wiping it on?
also...i plan on finishing by spraying 1-2 coats latex or solvent based low sheen lacquer...thought?
Once they approve a sample, you don't want to change horses in mid-stream. As far as the apprentice goes....40 lashes is in order. I would get some scrap maple and try starting with a honey stain before you just attempt to do a whole cabinet. If it doesn't work on the scrap, you are only out one piece of scrap. If it doesn't work on a cabinet, you're worse off than when you started.
I would never do a job like that without a chemical strip and sand. Id use a water based dye to even the tone on all the pieces, then come back with an oil based stain to achieve final color prior to spraying with solvent based lacquer.
Don
I would almost always follow TRBaker's advice, however in this situation, you may want to prepare a sample without the honey and see what the customer prefers. Show them both, side by side. I would even push the clean (no honey) sample. You are going to run into issues with aged lumber where the new stain is going to take differently peice to piece based on the original application, the partial sand, and the years of use.
I think you are going to have issues trying to match a stain that is potentially decades old, so you may be best to strip them all down to just wood and then apply whatever combo of stains the customer wants.
I concur with dwacker, trying to remove some, but not all finish is incredibly difficult.
  • 26,009 Total Members
  • Joseph b Newest Member ·
