baok Posted January 6, 2013 Report Posted January 6, 2013 I've just been out in the garage using a borrowed 13" surface planer (Delta 13"). And I'm exhausted. Obvious out-of-shape issues aside, this thing isn't really working as well as it should. I'm running cherry through; the wood seems a bit hard compared to the little cherry that I've used before. I can't seem to remove more than about 1/64" without it bogging down and the rollers don't seem to be pulling the material through the machine very well. There are obvious lines on the wood indicating nicks on the knives and the chips coming out are more like sawdust than shavings. When I've rested I'm probably gonna go out there and see if I can turn the knives around (manual says they are reversible) and maybe clean the rollers. Perhaps that will help. Any other ideas? Quote
tdale51@yahoo.com Posted January 6, 2013 Report Posted January 6, 2013 replacing/turning the knives and cleaning the rollers would be my advice. I think you're on the right track. You may also try waxing the planer bed, not sure if "bed" is the correct word, I'm referring to the portion within the planer that your stock rides across. Quote
baok Posted January 6, 2013 Author Report Posted January 6, 2013 OK, just got back. I turned the knives around to expose the new edges and that worked wonders. The rollers are now pulling the wood through as expected and I get take off as much as 1/16" per pass although it slows down noticeably. I only did that once. I stuck to 1/32" and everything worked wonderfully. Lesson: sharpness is important. More so than I thought. And on a related note: The Dust Deputy (that Marc recently reviewed and which won his chip separator contest) worked wonderfully. I bought it based on Marc's recommendation and I'm glad I did. I filled a trash can with chips from one 8'x12" board. Quote
rodger. Posted January 7, 2013 Report Posted January 7, 2013 When my 13" planer is bogging down, it's always the knives. Good thinking. The reversible side you are using may also be dull, just not as dull as the original side. Ask the guy you borrowed it from if he ever flipped the knives. How does the stock look after it comes out? With new knives and a light cut, the stock should look pretty darn good! Quote
Jfitz Posted January 7, 2013 Report Posted January 7, 2013 Glad it worked out! Sharp knives, a waxed bed and clean rollers are all required for top performance. Quote
baok Posted January 7, 2013 Author Report Posted January 7, 2013 I looked at the rollers while I inside the thing and they didn't look dirty as I thought they might. I probably should have taken the time to clean them anyway but didn't. The stick looks great when it comes out. I held it up to the light looking for scallops but couldn't notice any. Quote
