gregpalmer Posted February 9, 2013 Report Posted February 9, 2013 I'm working in my father-in-law's old shop full of old tools and the bandsaw doesn't work. As far as I can tell the bottom wheel is wobbling and the blade inevitably won't stay on. I can't immediately see any way of making the wheel stable. I was wondering if the tension on the pulley is not tight enough. Anyone know how to fix this? Quote
nateswoodworks Posted February 9, 2013 Report Posted February 9, 2013 I have an old Rockwell bandsaw and wouldn't trade it for nothin! As for your problem, do you know if he has ever had the saw running? The first thing I would do is take the lower wheel off and check the shaft to make sure it's not bent. The best way to do this is with a dial indicator but you should be able to get a guess-ta-ment by just taking a board that is pretty much the same thickness as the shaft and the base, spin the shaft by hand and watch the distance between the shaft and the board. You can even take it a step further by using feeler gauges to check it. If that checks out then if I were you the first thing I would do is put new bearings in both wheels, new tires, and a new blade on as well. As long as it's not a wheel that far out of balance (unlikely) you should be set. Quote
tim0625 Posted February 10, 2013 Report Posted February 10, 2013 depends on the wobble but could be a bearing Quote
gregpalmer Posted February 11, 2013 Author Report Posted February 11, 2013 I don't think I have a bent shaft or a wheel that is out of shape. I can move the wheel back and forth when it is not turned on. Also the wheels may not be aligned. Looks like I'll have to take it apart. Quote
nateswoodworks Posted February 11, 2013 Report Posted February 11, 2013 Either the nut holding the wheel is loose or the shaft is stripped If the nut is on the shaft a ways but won't tighten up there is probably a thread issue, you could always put spacers in to allow tightening. Aligning the tires is very critical but getting the tire secure is obviously first priority. There are many videos out there, Marc has a video on setting up bandsaws but its been a long time since I've seen it so I don't recall exactly what's covered. Basically put a straight edge across both wheels and shim if necessary. I do have a couple small shims in my top wheel to align them perfect. The nice thing is that since your saw is older all bearings and shims you can purchase at a auto parts store for a fraction of what you would otherwise pay. If you don't have a bearing puller either an auto repair shop or a machinist shop can do it for you for a small price. If I were you I would strip the saw down and go through it. It doesn't take long, the price is not that large, and the safety and performance will be far superior. Quote
wilburpan Posted February 12, 2013 Report Posted February 12, 2013 Even if you're only slightly mechanically inclined, sorting out a bandsaw is pretty easy. I have an old 1940's Walker-Turner bandsaw, and when I first bought it I managed to take it completely apart, replace the bearings, and tune it up. First place to start is to get some idea of how your bandsaw is put together. Luckily, there's a website called Vintage Machinery where people who really geek out about old woodworking machinery hang out. There are a lot of reprints of owners manuals and parts diagrams, and I'm sure you'll find one that matches your bandsaw. Delta reprints can be found here, and Rockwell reprints can be found here. Quote
