I've been trying to saw things with a panel saw as much as I can to build the skill. I have an issue with my return stroke.
As I draw the saw back through the kerf, the front of the saw will wobble back and forth. Does that imply that my arm isn't aligned well with the cut?
Hi Greg,
Here's a few tips.
Index finger pointing down the saw blade, helps your brain keep your stroke straight.
Cutting angle around 45 deg, although I must confess I don't even notice what angle I am sawing at
Relax and slow down. No death grip or agresive motions. Let the saw do the work and feel the blade staying straight.
Also check your timber is not pinching (kerf closing). Trial a few different pieces of wood to rule this out.
Make sure the saw is tuned well and that it is creating enough of a kerf, although you don't want to much otherwise you will get a drunken saw.
If you want to watch an entertaining video on saws and sawing take a look at this.
Finally practice, practice, practice, practice.
something most people overlook.
Which eye is your dominant eye?  Is it the same as \your sawing hand?  That also throws off your technique.  Trust me.  (It's not my only problem, but it is a big one.)
Also, Shannon has a video of another approach.
I was out sawing last night (ripping this time - which is new for me) and I think the problem is that my arm is not properly lined up with the cut. For some reason it is really difficult for me to hold the tool gently enough - if I don't constantly correct myself, I end up with a death grip. Part of this death grip is that I seem to go off center.
Practice is the answer.
I've been only doing small cuts - if it's a long one (like last night) I've been going over to my band saw. The fact that my best blade broke and I haven't gotten a new one yet forced me to use a hand saw. Perhaps I should not be running to the bandsaw so much.
Hi Greg,
I am cutting lot's of dovetails by hand at the moment for my tool chest project and I know exactly what you mean about death grip. Yesterday evening before heading home I wanted to get a section finished so I was rushing and therefore tense, the saw was harder to start of and the results less good. However this time, working in my lunch hour, no pressure, relaxed and a much better outcome.
Keep up the practice.  :)
Greg, that wobble and vibration is usually an indication of bad alignment.  Also try not to drag the teeth across the wood on the back stroke as this will cause vibration as well as tire you faster.  It probably dulls the teeth faster too, but that is my least concern.  I recommend the best thing to do is film yourself sawing.  Once from the front and once in profile (or two cameras all at once)  It will become glaringly obviously where your alignment issues lie by watching how the saw wiggles.  I guess the real question is how are your cuts coming out now?  If they are out of plumb and square then obviously things need to be fixed.  If not, this is not a huge issue but one that fixing will help with your efficiency and fatigue rate.  Usually the backstroke wobble is caused by a little hitch in the elbow on the stroke which is fixed by shifting your body weight out over the saw.  I did a "clinic" with my hand tool school guys and spend an hour with 4 of them individually to diagnose sawing issues and every one of them had that little elbow kickout which was fixed in 5 minutes and resulted in better and faster cuts.
  • Who's Online   2 Members, 0 Anonymous, 52 Guests (See full list)
