Wood dye for curly maple
Building a top with a curly maple field and a cherry border. Want to pop the grain on the maple. Already glued the cherry to the top so both will get dyed. Any suggestions for what color dye?
The cherry has some figure as well so I'm thinking it will pick up dye as well.
Was going to use transtint dyes like marc did in his video.
I did a sample board of dyed curly maple a year or two back. I liked the way Honey Amber turned out. I ve got a photo of it on my blog. Woodintosawdust.wordpress.com. Just scroll down about 6 or8 entries to get to it. The post is titled "working with dyes".
Adam
I'd go with a Honey Amber as Adam suggested but start off very lightly colored and darken it if necessary. Transtints is wonderful for this as you just add 5 or 10 drops to darken the dye solution. I suggest you mask off the cherry. Honey amber on cherry equals mud. I had the same challenge with ash surrounded by cherry shown here.
-Randy
Not to ask a dumb question but is the top all solid hardwood maple surrounded on all four edges by solid cherry?  If so what color dye might be a moot point.
Thanks for the help. Sounds like honey amber will work. I didnt want to have to buy a bunch of colors, figured someone here had done it before.
Randy, did you just use painters tape? Any bleed through ?
Dcustoms, the top is glued up solid maple and the edges are solid cherry, you don't think I should stain at all?
I decided to try some more colors so I made another sample board today. I'll post a pic tomorrow as soon as I get a few coats of poly on it. I must say that orange looks pretty nice too.
Adam
Amber dye on cherry isn't color compatible. Yellow and red are two primary colors and they are completely different. Mask the cherry wood with painters tape when spraying the maple. Remove the tape immediately to avoid any bleeding. Spraying in a mist will reduce bleeding. Mask off the maple when spraying the cherry.
You are attempting an advanced finishing technique with finishing two species side=by-side. This isn't a technique for the faint of heart. You may want to experiment first.
I look forward to hearing of your results.
-Randy
What I was getting at is anytime you glue up a solid panel and then edge the whole thing all the way around with wood you have made it so the panel can not move.  The expansion and contraction of the top will cause the maple top to crack and the cherry edging to break off.  Really the best way to achieve the look you are going for is to use a maple veneer then edge it with solid cherry.
  • 26,009 Total Members
  • Joseph b Newest Member ·
