First impression of honduran mahogany
I bought a 2BF piece of honduran mahogany from my hardwood dealer a few weeks ago. I have left it in my basement since to acclimate and find it's way to my moisture content, etc.
I went down in the shop today to play around with it, and see what is so good about milling mahogany. I face jointed one side just enough where it would sit flat on a table, except for about 3" of one corner. I didn't want to take off too much. It was purchased at a thickness of a little over an 1" and I took off 3/32 or so on the jointer. I edge jointed one side, and then ran the other side through the table saw to take off a total of maybe 2/8" width wise.
First, the wood is beautiful. Second, it cuts like butter. Seriously, I could not understand it. It sounds solid as petrified wood, and pretty heavy too. I thought I would have to watch my feed rate on the table saw, but it just went right through. I love it.
However, for $11/BF, I don't see me using this wood too often :( I bought it on sale for $8.60/BF, though. So I saved a little money.
Anyone else have a good experience with mahogany?
Yup Ive put these tables in at least a dozen different cafe's.
Didn't you say you were going to make a video about one of those tables? I might have misread that post, but if not, I would still be looking forward to it.
Yes I've made several guitars with Honduran Mahogany. You're right it cuts like a hot knife through butter but it is now becoming harder to source for me. I do have a small stock left. Now turning to African Mahogany and that too cuts the same and is easier to obtain.
What are the differences between African and Honduran Mahogany - in your experience?
I built my dining table from H.Mahogany and it's a dream to work. It is relatively soft though, use a good tough finish for anything that will see regular use like tabletops.
If I'm completely honest Honduran is slightly easier to work (they both are a dream to work with hand tools) and gives a warmer tone (musically) but that is only comparing side by side identical models built with the two different timbers but with the same hardware. The problem with Honduran is that it is becoming very difficult to get hold of now, where I live, and I'm led to believe this is thru over harvesting and export quotas. The African stuff is a related genus but in my ears still sounds similar and works almost as well.
They both are similar densities for example 2bf from both weigh about the same. I haven't actually weighed them but you get a feel for things after a time handling them. But the main thing is that African, for me at least, is far easier to obtain now.
I've used a ton of Honduras Mahogany in the past but the price got outrageous. I've since switched to Royal Cedar and Spanish Cedar. They both work about the same as Honduras, but the Royal Cedar doesn't smell as potent as the Spanish Cedar. Both are used by unscrupulous woodworkers to be marketed as Mahogany. They look that much alike.
Yes Spanish Cedar I've used to make guitar necks. Another very easy to work wood that is neither Spanish nor a cedar. Not sure how it came to get that name, probably marketing, but it's actually called Cedrela. It smells wonderful when you work it and I think it is used to line humidors and cigar boxes.
Sapele is the choice for an alternative to honduran mahogany. It's much more cost effective, and people argue that it's got a warmer tone on a guitar than honduran mahogany. I guess form your own opinion on this.
I've used that too but find it tears out a little more readily. Having said that it is a very good alternative being easy to get hold of and fairly cheap. I sometimes build necks with a laminate comprising quartersawn sapele, maple, sapele, maple, sapele and that minimizes twist over time. It also give a pleasing twin maple stripe through the back of the neck.
It is a relatively light density and it's very true that it does indeed sing as a tone wood on electric bass bodies and electric guitar bodies. When you tap it when it is still in board form it actually does resonate :)
You are correct, Terry. It is used in humidors and cigar boxes. It got its name from its point of origin; Central and South America and the Caribbean, where they speak Spanish and make some of the worlds finest cigars.
