G S Haydon Posted June 6, 2013 Report Posted June 6, 2013 Does anyone know why some of the audio is missing from this video . Is there a conflict with another tool maker? Quote
mikem Posted June 6, 2013 Report Posted June 6, 2013 Yes, I am pretty sure he was comparing them to Lie-Nielsen. Rob used to be a distributor for them. When Lie-Nielsen changed their sales model for their tools, they cut their ties to most of their distributors (Woodcraft included). In a few of his videos, while touting his own tool line, he made some comparisons with Lie-Nielsen that likely he was not authorized to make. As a result he was requested to eliminate those portions of the video. Quote
G S Haydon Posted June 7, 2013 Author Report Posted June 7, 2013 Thanks Mike, I wondered what it was all about. Quote
HolzMechaniker Posted June 11, 2013 Report Posted June 11, 2013 Yes, I am pretty sure he was comparing them to Lie-Nielsen. Rob used to be a distributor for them. When Lie-Nielsen changed their sales model for their tools, they cut their ties to most of their distributors (Woodcraft included). In a few of his videos, while touting his own tool line, he made some comparisons with Lie-Nielsen that likely he was not authorized to make. As a result he was requested to eliminate those portions of the video. Well that thar explains why Woodcraft had those blades on clearance.... Quote
duncumb.fc Posted June 17, 2013 Report Posted June 17, 2013 Just to jump in, I have an IBC Cosman blade in my jack. I've probably sharpened it once since the day I bought it, and I have used it fairly regularly over a year and a half. It's still pretty sharp. Yes I'm lazy, and I should have sharpened it many a time since then, but what I mean is that if you want a blade for a go to jack plane, they're fantastic. While I don't really rate A2 steel, they definitely aren't kidding when they say it has good edge retention! Fraser Quote
G S Haydon Posted June 17, 2013 Author Report Posted June 17, 2013 Where did you buy yours from Fraser and what do you sharpen it on? Quote
duncumb.fc Posted June 17, 2013 Report Posted June 17, 2013 I got mine from Classic Hand Tools, but it definitely wasn't cheap... However, I'd still say worth it. I use a 1000 and 8000 water stone. Fraser Quote
G S Haydon Posted June 17, 2013 Author Report Posted June 17, 2013 Thanks Fraser, I had looked for these in the UK but had no joy. Not looking to take the plunge just yet although I will give them consideration when my irons get too short. How do you reckon they would fare on a fine oil stone? Quote
duncumb.fc Posted June 18, 2013 Report Posted June 18, 2013 You found them here I take it? I have very little experience with oil stones, only using them once or twice, but they seem very similar to water stones really... I reckon it would be fine, besides I've never heard anyone say "Oh no, I can't use A2 because I've got an oil stone"! Sadly not cheap, but for a stock removing, every day plane, I think they're perfect. For my jointing and smoothing I prefer either an old sweetheart (or earlier) Stanley USA blade, or out of the new bunch I'm very partial to the Clifton irons. Their hot forging process definitely seems to produce great results regarding edge sharpness... I can get the Clifton much sharper than any A2 blade I have, but obviously the blade wears back quicker as a pay off... Fraser Quote
G S Haydon Posted June 18, 2013 Author Report Posted June 18, 2013 Fraser, I did indeed find it there with some other rather choice offerings. I'm very lucky, I have a clifton iron! I have had it for some time and almost forgot it was in my day job No4 smoothing plane. Not really the place to get the best idea on the performance! Once I get my #4 refurb done I was going to try it against the standard record blade. Should it work well it will probably appreciate life in my tool chest more than my day job tool box. Glad to hear you have had good results with the clifton, I hope I do to. Quote
calblacksmith Posted June 19, 2013 Report Posted June 19, 2013 I just put one into my #4 Stanley, even with very VERY careful; fitting, I got nicks on the edge in the file/fit/file/fit process. I will regrind on my low RPM wheel then onto water stones for final work. I have not had much of a chance to use it yet as it was just installed. I think I am going to open the mouth a little more on the Stanley, the blade has about 0.020" clearance with the frog in the rear most position, there is a lot of room to move forward so opening the mouth will give me more adjustment room. It seems to be a well made iron and breaker and like others said, it was not cheep, I expect it to serve well but at this point for me, it is all a guessing game. I am comforted by the good reports above in regards to performance. Quote
