using markers for coloring
I have been experimenting with decorated patterns on my lathe.  I use colored sharpies to basically write on my turnings and when I use spray shellac on them the ink runs.  im guessing the ink run is from alcohol mixed in the shellac so it can be sprayed.   what is a good alternative finish that wont make the ink run all over preferable something I can put on while my lathe is spinning.
I'm pretty sure that Sharpies use an alcohol based ink. Pretty much any finish other than shellac should work. I like the idea of using the markers. It's like using dye with a precision applicator.
You may have better luck with touch-up markers made by a finish manufacture. Only problem, they have a thicker tip and not pointed like some sharpies.
http://www.generalfinishes.com/retail-products/touch-products-finishing-supplies-sundries/repair-scratches-nicks-in-furniture#.UkBWRFOE6dc
-Ace-
You can buy refillable markers at an art supply store. Many tip sizes and some have mixing balls. You can also get acrylic markers that will not lift after dry.
forgot about acrylic markers.......but are they soft enought or do they have a hard tip.  ill have to look in my blick book
my experiments all melted with my finishes.  im thinking of trying coloring pencils but I think that would just grind it down not really color the wood.
but I found this guy who uses lacquer http://www.youtube.com/watch?v=Fc8j1BpYFsM
here is an old experiment I did with decorating the wood and then coloring it. in the photo I was just playing with some tools that I had just made.
if you want to know how to build a couple of them let me know and ill walk you through the manufacture of the decorating lathe tools
  • 26,009 Total Members
  • Joseph b Newest Member ·
