I was hoping that someone could help me figure out what I'm doing wrong here. I am making a child's rocking chair. I have made one before using a straight cut pattern bit, but had to flip it(the wood) over due to the thickness of the wood. I bought 2 up cut spiral bits that would cover the thickness. when I tried to use it in my router table both times it grabbed the wood, kicked back, cutting deep into the blank. Don't know what's going on as I'm very new to wood working. I am trying to attach a picture, but not having much luck.  Any suggestions would be appreciated..
thank you,
slmize
you are cutting too much material at one time. are you pattern routing (i.e trying to shape the outside if the wood) or are you trying to cut a groove through the wood? if you are pattern routing cut as much as you can with a jigsaw and then just use the router to clean it up. This depends on the size of the router bit, but if you are using a 1/2" cutter (not shank size, but the size of the cutter itseld) you should only trim away 1/8" or so at a time. if you cutting a groove, cut it only 1/4" deep or so at a time.
Also you might be climb cutting. you wantto push your wood into the rotation of the cutter, not with the rotation. if you cut with the rotation the cutter will grab the wood and sling the wood across your shop, like a baseball pitching machine. google "router climb cut" to see what i mean.
I am pattern cutting. I dont believe im taking to much because it happens as soon as i touch the wood to the bit. As for feeding the wood, i am feeding the bit from right to left. Also its more of a kick back than pulling away from me. I will keep trying to post a picture so i can show what it doing. I may not be explaing it right.
Thank you
Find a way to use a pin. You are not steady enough free hand to start the cut. If nothing better on a small table, clamp a board to one edge of your table. It works better when the pin is closer to the cutter though.
also i wouldn't start at the corner if that is what you are doing. that is where grain changes direction and gets caught on the cutter. start in the middle add follow through the end (rather than going around the corner) and then the turn the board around and do the other side.
  • Who's Online   1 Member, 0 Anonymous, 39 Guests (See full list)
