Dakia Posted November 26, 2013 Report Posted November 26, 2013 I've just been getting going in woodworking and I bought myself a table saw, band saw and a jointer. I was looking on CL to pick up a planer on the cheap and and found out that my neighbor has one that he doesn't use. He offered to sell it to me for dirt cheap. I realize that it isn't the best planer out there, or even that great of a planer, but this is for a price that practically means he is giving it away. Where I am running in to a problem is that the planer is a Pro-Tech CS6007. These aren't made anymore apparently and I can't for the life of me find any information as to a blade that would fit the planer to replace the dull blades that he currently has on it. I've done some Google searching and I'm just not sure if I am looking in the wrong places or if I'm an idiot. Does anyone have any experience with this planer, or would someone be able to point me to some blades for it. Quote
Boatworks Today Posted November 26, 2013 Report Posted November 26, 2013 I've used these guys before without any problems. As long as you know the length, width and thickness of the original blades they should be able to cut whatever you need.. Quote
Dakia Posted November 26, 2013 Author Report Posted November 26, 2013 I've used these guys before without any problems. As long as you know the length, width and thickness of the original blades they should be able to cut whatever you need.. Thanks. The problem the guy who owns it has run in to is that the blades are double sided and reversible. I'll talk to the guys at that site and see what they can do for me. Quote
wtnhighlander Posted November 27, 2013 Report Posted November 27, 2013 My local Lowe's home center actually carries replacement planer blades like you described, with cutting edges on both sides. Might be worth looking into. Quote
Byrdie Posted November 30, 2013 Report Posted November 30, 2013 I have a Protech 13" planer and it uses the double sided blades. I'm not sure of the model number, never been good at keeping track of that kind of stuff. What I do know is that, last time I checked, Menards still has the replacement blades. I think I found them in the same aisle with the saw blades. Quote
Dakia Posted December 1, 2013 Author Report Posted December 1, 2013 Thanks for the help guys. I ended up getting a Delta for only slightly more, so I've got this one covered. Quote
