ChetlovesMer Posted January 13, 2014 Report Posted January 13, 2014 Okay, so I got a really neat Christmas present this year. It was a build your own block plane kit. Pretty thoughtful, I thought. I mean who doesn't need another block plane? And who doesn't like building their own tools? Anyway, the kit I got is from Woodsmith and I put it together this weekend. Here's my review of the kit: 1 - Construction - In my opinion this was the most disappointing part of the kit. It was simply too easy to build. The kit basically screws together. You have to countersink the holes in the bronze parts and theirs quite a bit of shaping the final pieces, but seriously you could probably build the entire thing in under an hour. It took me about 90 minutes. I shaped the front end of mine slightly different than the way the kit advises. You have a fair amount of freedom with the shape you end up with. 2 - Quality - About the only thing I can judge here is the blade. The plane came with a Hock blade and I was really shocked at how really dull it was. The back needed to be flattened and it was just stupid dull. Perhaps I'm spoiled by the condition my LN or LV blades come to me, but you'll probably spend more time honing and sharpening the blade than you will building the kit. 3 - How's it work - Really really well. Is it as easy to adjust as my LV? Nope, but its not difficult. And once set up, it cuts as well as the LV or any other block plane, really. You adjust it with mallet smacks, which I think is a good exercise to remind us that's the way all planes used to adjust. 4 - Final analysis - Who should buy this plane? This plane is perfect for anyone who needs a block plane and doesn't want to spend more than 50 bucks for it. I would avoid thinking of this as a plane building exercise. Instead think of it as buying a plane which requires some assembly. Once you have the kit, in about an hour or two you'll have a block plane that will work great, be easy to tune and perform well. Will you learn a ton about how to build planes? No. Will you have a very effective block plane when your are done? Yes. 2 Quote
wtnhighlander Posted January 14, 2014 Report Posted January 14, 2014 Nice review, Chet. Good to know this isn't a particular challenge. I'm surprised about the Hock blade being shipped dull. Do you suppose that is because it is part of 'DIY' kit? Quote
ChetlovesMer Posted January 14, 2014 Author Report Posted January 14, 2014 I'm not sure. What I'm wondering is if perhaps Woodsmith buys them by the ton and maybe doesn't store them perfectly in their assembly plant for their kit? Or maybe I just got unlucky. The blade is actually fine now, but again I was surprised. Quote
