Finishing Reclaimed Wood Base for Butcher Block
Hi All I've poked around the site a bit trying to find an answer to my question but no luck (may be more of a taste thing). I am in the process of building a butcher block workstation out of hard maple for the block and reclaimed walnut for the base. I've done some wire brushing and light sanding to the walnut but I'm not quite sure how I should finish it? I'm going to be using Watco butcher block oil for the top but I need suggestions for the base? I don't want to alter the color of the natural wood but I do wan't to protect it. I don't have the ability to spray a finish so I will have to wipe or brush it on. I appreciate any and all suggestions.
Thanks,
General Finishes Arm-R-Seal always looks good on walnut.
Do you have a picture of the walnut?  Reclaimed can mean lots of things.... if you have old finish on it, or lots of checks and cracks, or a rough sawn surface, etc, those can all dictate which approach might be better.
Here are a couple of shots of the lumber semi cleaned up.
are you going to leave it rough or plane it all smooth?
Leave it rough. Just some sanding.
In that case I would just use boiled linseed oil and wax. Use a dark wax so that it does not dry white. If you don't have/can't find dark wax, you can make your own by mixing a little dark oil based stain with a commercial paste wax.
Thanks I'll give it a shot on some scrap.
  • 26,012 Total Members
  • JAR Newest Member ·
