Filling and finishing Powder Post beetle/bug holes
I'm currently working on a joint commission project building a chiropractic chair from oak. The deal is I build it and the guy whom owns a sawmill provides the wood for a cut of the commission. The wood I have gotten from this guy is actually really nice and I have gotten a lot of board feet for free in the past just because he had it lying around or it was left over from a log a client had. The oak I'm using is white oak and most of it is nice except a few pieces have what I believe are holes from powder post beetles.
I know I'm going to get lectured about an infestation, but I know that the beetles are gone or dead inside somewhere! Like an idiot....I decided to fill the holes with a wood filler made by 3M that I had never used before and I proceeded sand, pre-condition, and stain with an oil based stain. Well the filler never stained and stayed the same color even though the packaging says it is stain-able (I should have known better). Now I have boards that are stained "golden pecan" with tiny spots of white/yellow. I attempted to scratch into the holes a bit and apply stain with an artist brush but no luck. It still looked dumb so I decided to make them look darker so I used a darker oil gel stain and it only stained a dark ring around the filler........ now it looks really stupid. I'll try to get some pictures later today but I was wondering if anyone had any suggestions on how to save my project.
Here is my finishing method I have planned.
1# Oil Pre-conditioner
2# brushed on Oil based Stain Minwax Golden Pecan
3# brush on 2-3 coats Minwax Fast-dry Oil Polyurethane sanding with 320grit in between
Any good fillers that are available? Big box store options? Make my own? Finishing technique to make them look less noticeable?
:(  Its driving me crazy and I really don't want to sully my relationship with the sawmill because I've got a great thing going here.
Again I will have pics soon!
I have used ca glue and a contrasting sawdust, like padauk dust on maple; looks awesome. You can try to blend them but I like the obvious contrast.
Sent from my T-Mobile G2 using Tapatalk 2
CA and sanding dust of the same wood blends better than anything else I have tried.
would the filled hole still be stain-able or would I need to add stain to the saw dust then mix with CA glue? Would that work with an oil based stain?
Cured CA glue will not accept any stain or oil finish and the filler will reasonably well to the surrounding wood if finished with a clear film finish like blonde shellac or lacquer. Oiling the wood increases the contrast. I've never tried adding stain to CA glue since it dries so quickly.
True that the CA & dust filler won't take a stain. However, it is generally darker than the bare wood anyway (at least in my experience), and for small defects like worm holes, should look decent. What I do is to sand the area around the defect to a high grit, usually 320. Save some of that dust and fill the defect with it. Then flood the defect with a very thin type of CA glue. Avoid getting it on the solid wood as much as possible, but having sanded to a fine grit, it shouldn't soak too deep. Give it an hour or so to fully cure, then sand flush. On a really deep hole, you may need to fill it in stages to make sure the glue has fully penetrated the dust. As McQ said, this works best under a clear finish. If you apply stain, especially on a light colored wood like maple, you may have to touch up the filled area with an artist's brush and pigments to get a good color match. I have done this before, painting in some growth rings and check lines, to make a filled hole look like a stabilized knot. Works pretty well if you patience and a steady hand.
Do you think the "filler mix" would cure if I were to take my oak dust and add stain to the dust first before and letting it dry. Then mix with CA glue and fill the hole? I will be coating the board with an oil based poly.
I've already stained the boards so sanding is out of the question. Are you talking about sanding on a board that already has stain applied?
If sanding is out of the question I would hesitate to use ca glue. You could try taping off the area and trying very hard to keep it flush with the surface. What I usually do is fill the hole with sawdust then add a drop of glue. If the hole is really deep I will do this in layers, but it usually comes out slightly mounded. As for the mixing, I have no idea. Try a small test on scrap and let us know.
Thanks for the info guys. I tried a scrap piece of unfinished oak last night. I put the fine dust in the hole and dropped CA glue on top. The fill is noticeably darker but this should work to my advantage with a stain and oil poly applied. Tonight I'm going to mix up some dust and stain to see how it works with the CA glue. I'm also going to get a test piece stained to see how is will work on my actually project boards. If your even interested I'll let you guys know how it goes!
... If your even interested I'll let you guys know how it goes!
Well I'm interested for one. It's all part of the learning process and by sharing it means that others don't have to do the same experimentation. Looking forward to seeing the results.
