OrneLeather Posted May 24, 2014 Report Posted May 24, 2014 Hi everyone, This is my first post on here. I've been a fan of the Woodtalk podcast for awhile, but I primarily work with leather rather then wood. Anyway, here is my question. My leatheerworking hobby is starting to gear up, and I'm finding I need more storage boxes in more sizes and a bit cheaper then I can find for sale. Being fairly handly, I figured I would just knock them together myself. Since I'm currently living in an apartment, I can't use power tools both for the noise and the mess. So I'm looking for the hand tools I would need to cut parts for basic plywood boxes. I have a drill plus all the basic home repair tools, but I basicly have nothing for cutting and shaping. What I figured I would do was rip down the sheets to the sizing I want, use either rabbet or box joint, glue and screw, and call it done. I was leaning twards a basic rabbit joint, so I woud buy a decent saw, and either a rabbit plane, sholder plane, or router plane, and that would work for what I want to do. My first thought was to use 1/2" plywood and plane with a 1/4" pane blade to make things simple. Does anyone have any thoughts on what you would buy starting from zero? Quote
G S Haydon Posted May 24, 2014 Report Posted May 24, 2014 Welcome Glen. From my perspective I would do small ammounts of work on ply with just hand tools but in broad terms it works better with power tools. Perhaps another way to go is use pine for the box and ply for the base. Rabbets, glue and nails would do for the box. The base could be held within a groove although just nailed and glued to the bottom of the box with a trim applied to blind the ply would be easier and requires less tools. For the lid some more ply with a lipping or moulded trim applied to the edges and a simple but hinge perhaps. Tools for this can be very simple, hardpoint saw, square, chisel, hammer, screwdrivers. Hope that helps! Quote
..Kev Posted May 24, 2014 Report Posted May 24, 2014 Another option might be to have the big box store rip you some strips to size or, check with a local cabinet shop for some of their off cuts that may be just the right width for you. Pallets may be another source of material as well. Then a hand saw to cut them to length. For the bottom, I like One-Eyed's idea but, I'm assuming that you also don't have the ability to cut rabbits. Going with this thought, screw the plywood bottom from the sides. If you don't want to see the screws, countersink them and put in a few plugs. You can buy the plugs at the big box store if you don't have the tools to make them yourself. 1 Quote
