What food safe finish should I use on butcher block counters?
Hi folks. I am planning to redo my countertops in my kitchen and bathroom. I purchased some butcher block material made up of jointed red and white oak. I would love to finish them with a thick layer of polyurethane but that is not food safe. Can anyone tell me what finish would have a beautiful appearance like varnish or polyurethane and be resistant to scratches from knifes and be waterproof but also be FDA approved and food safe? Thank you very much for your suggestions in advance.
Checked in to bar top epoxy? And generally speaking, most wood finishes ( hard ones, at least ), are food safe once they are fully cured. The only concern I would have is if you used the surface as a cutting board. In that case you might flake chips of the finish into you food, which can't be good...
If you intend to use it to do any cutting then I personally would avoid any sort of film finish. I think even a very hard film finish will still show scratches over time from a chef knife. I would just use mineral oil to give some protection from water in that case. If you never plan to use the surface to cut on directly then I would default to what wtnhighlander suggested.
I used genral salad bowl finish on a countertop build - looks great and has held up really well. Do a forum search for "momster counter top build" and you can see the details.
thank you for your suggestions. I do feel hesitant using epoxy with food contact. I know it will cure but if you read the label of any epoxy can it is incredibly toxic and cancerous stuff. And no word of FDA approval. Does anyone know of a bar top epoxy which is demed less toxic or has FDA approval? thanks again.
  • 26,012 Total Members
  • JAR Newest Member ·
