finish for red oak tote
I purchased an old type 7 jointer plane whose tote was broken in two places (middle and top tip).  I contemplated repairing it but decided on carving out a new one instead.  The hardest material i had on hand was some red oak.  I may need to tweak my carving a bit to fit under the lat adj. and be more comfy on the index finger, but i'm curious on what i should use to finish it with when it's done.  I've seen others recommend to use danish oil, blo, shellac, or some combination of the three.  Though, i don't think i've found any other totes made of oak.. will the open grain have any adverse affects that should be considered on a tool handle?
Also, since it seems that the original totes are somewhat prone to splitting in those 2 spots, i thought i'd try orienting the grain vertically instead.  I suppose now the toe portion of the tote may break off, but we'll see.  I did make the replacement tote about 3/32" wider and taller since the old one seemed to feel a bit cramped.  Since both orientations seem to present a flaw, i may try experimenting with laminating a 1/8th" strip of cherry down the center (would that be wide enough to lessen the probability of splitting?)
This guy was the first thing i had ever carved.  I'm actually a bit surprised with the ease of being able to make it have smooth and consistent radiuses.  I may make another using the tote Stantley templates that LV provides and just zoom the image by a small amount to give more room for the width of my hand. I kind of wish i had stumbled upon them before i cut out the first one :P
post-15737-0-28379300-1403512823_thumb.j
post-15737-0-29940600-1403512894_thumb.j
post-15737-0-96370600-1403512894_thumb.j
post-15737-0-71315200-1403512895_thumb.j
That tote looks great! I think laminating is a good idea to prevent breakage. As for oak's suitability as a tool handle, I think it will be fine. If you think the pore texture might bother you, apply a grain filler prior to finishing. In regards to finishing, use whatever feels good to you. Shellac alone might be prone to scratching, but used with oil or poly is makes a nice smooth finish, that is pretty tough.
Something to consider on the next one you make: drill the through-holes while the block is still square....
haha, yea.. i hadn't considered the holes until after it was carved up.  I could likely still drill them easy enough on the press by clamping the handle to the side of an L-shaped jig.  Though, I think i'm going to make a new one and relegate this first one to be used on a jig.  I'll be sure to drill holes on that one prior to carving to make things easier :)
I'm not too concerned about the oak eating up my hands as i am curious about what wont end up looking/feeling nasty after it's had sweaty hands using it for a while.  Would mixing shellac with a danish oil be better than just using danish alone?  Would that be a 1:1 mixture, or do you mean to do a coat of one then follow with the other?  (sorry for all the questions, i'm pretty inexperienced with finishing).
I have yet to try mixing shellac and oil, although I see turners do it on Youtube a lot. What I have done one some furniture pieces is to seal the wood and build a thin film by rubbing in a very light cut ( .75 #, maybe) of shellac. Then I wipe on a single coat of thinned poly to enhance water resistance. I like the tome provided by the shellac, even the blonde seal coat stuff. The single layer of poly is pretty clear. It has been wearing quite well under daily exposure to cold glass condensate and ceramic coffee mugs. I rub in the shellac because it dries quickly, allowing me to build the finish without a lot of waiting. Also, I don't own a spray rig.
I'm out of likes so I'll just have to post that I agree with the idea of a lamination to support the spots that most commonly break.  Nice job of shaping this one even if it just ends up being a template.
  • 26,009 Total Members
  • Joseph b Newest Member ·
