HI folks,
I purchased a set of replacement blades for my jointer (Craftsman 6" Model 103.20660). I am trying to install and adjust the height of the blade as the old blades were very worn down and chipped. Wnen I put the new blades in at the previous height, the project way over the top of the table. The manual states "All three blades should project 1/16 inch at the right side of the cutter head. With the edges projecting slightly below the surface of the tables, lightly clamp the blades in position with the socket head screws and wedge provided for each blade. With a straight edge on the tables, position the blades by adjusting the height of the two flat socket head screws until each knife edge just touches the straight edge lightly at either end of the blades as the cutter head turns by hand"
My question is where an I suppose to be measuring the 1/16 inch at? Is it the top of the blade to the cutter head? When I turn the cutter head by hand, the blades should just barely touch the straight edge, so does the 1/16 inch distance need to be measured?
Thanks in advance for your input.
I think they mean the end of the blade 1/16 past the side of the cutter head , sideways.
When you have the straightedge on the outfeed table the knive blades should just touch the straightedge, barely lift it but not cause it to move or travel as you rotate the head slowly by hand with the machine unplugged.
This can be slow fussy work to adjust. Bring patience , no distractions and a steady hand.
Well, I found out what happens if you do not tighten the wedge screws tight enough. I owuld love to share the pic of the shattered blade with you guys, but I can't figure out how.
Ooo can't wait to see these ... Glad you are ok though that could of been bad
Under tightening is worse mine threw a knife into my dust pan and scared the hell out of me. I should get a pic of that. I keep the knife as a reminder the hss knife is bent almost 90 from hitting the galvanized pan I made.
It scared me too. Shards of metal flying through the air with the greatest of ease. It wedged between the cutter head and the under side of the back table. Seized the motor momentarily. I got it shut off quickly so i do not suspect any motor damage. The sad thing was I had all 3 cutter heads adjusted to the perfect height (as one can get with limited tools). I was face jointing a piece of hickory when it happened. My wifeypoo is a tad bit upset as I now get to by another new set of blades. These came in this morning.  Live and learn. Thomas Edison said "I didn't fail, I found 2,000 ways how not to make a light bulb; I only need to find one way to make it work."
  • Who's Online   1 Member, 0 Anonymous, 43 Guests (See full list)
    26,008
    Bob44
    Bob44
