Converting a book case into a rolling cabinet
I was given a very solid case made form solid wood by my son-in-law (he swears I gave it to him  (I cannot remember to be honest) which is in rough measurements ... let me see .. about 300mm deep by 1500mm high and wide. The surface is pretty beat up being in the shed for years but all of the joints are sound.
What I would like to do is convert it onto a rolling cabinet. My plan is to put a divider down the centre, build some drawers of varying sizes, maybe to incorporate a sand paper storage of some type, then install the drawers using some full extension slides form the local hardware store.
I am planning on using 20mm for the base and 19mm for the sides in hard wood ply for the drawers then add some drawer inserts to store the tools.I am thinking a couple of sheets should suffice.
Can you see any flaws in my (cunning) plan. Any ideas on construction? I was thinking of rebates rather than the more time intensive box/dovetails.
My hand tool storage at the moment is just open shelves and some wood boxes I made. I hope to use this cabinet to store most of my hand tools.
I am at work so I don't have the exact measurements or photos with me.
Yes ... that is my chief consideration but I am thinking about moving the front wheels out a little way from the base. Also the lower drawers will be deeper and contain heavier items so that should keep the centre of gravity lower. The actual case depth is more than 300 - maybe 350 but the drawers will be about 300 to fit inside.
The other alternative is to do the same mod but wall mount it. It does not have to be rolling and even if I do and am not happy with it I can simply remove the castors and wall mount.
I am mainly after advice on the drawer design options. I really like the way Mark S mounted the drawers inside his old assembly table. Fairly straight forward construction and solid enough.
Should I rebate and glue or should I go for something a little stronger such as finger/box joints? I am vacillating between the ease of simple rebates and the strength and durability of the box joints.
16 to 19 mm thick stock rabbeted , glued & pinned with a 6 mm ply bottom in a dado 13 mm up should be sturdy enough.
If on casters I would extend the base to double the depth of the bookcase.
Whew that was a lot of converting to mm for an answer.
LOL! As reading I thought to myself, "Hot damn! That Steve sure has his metric down."
OK, I am working from home today and popped out to re-measure. 330mm deep (300 drawers will fit perfectly), 1040 high and 1200 wide. Thanks Steve for the guide on sizes. Will 6 mm (1/4) be enough for the base? Especially if I want to put some heavy rubbish in the drawers. Is 12mm base an overkill? Maybe even 9mm. They have that at the local hardware. (I come from a family of overengineers.) Maybe the deeper, lower drawers up to 9mm then thinner for the smaller drawers.
I was thinking of a series of open slots at the top with 3mm separators for sandpaper sheets.
Sort of thinking out loud here.
Conversion table (rough) (our ply is in metric sizes)
3mm = 1/8
6mm = 1/4
9mm = 3/8
12mm = 1/2
19mm = 3/4
Hi Yanis. What a pleasure to hear a fellow Aussie speak in mm! If you want the drawers to look good as well as be strong go for finger joints otherwise the lapped joints will do the trick and at the back just let the back into the sides a little, maybe 5mm.
Regarding the tipping issue I would make a large base that the unit sits on with a hinged lid at the front. This way if all the drawers are open you will not have an issue. Make the base double the depth of the unit, so maybe 600mm. A lid that slopes down slightly giving you approx. 250mm to access the new space under the drawer area. Send us some picks as you work through it.
