Two car garage dust collection
Hello All,
I am sure that this has been covered a few time but I can't seem to find anything that matches up with what I am wondering. So I turned my two car garage in to a shop, when I say two car garage I mean it you have to back the car on the right in just to be able to open doors. Now my question is I am looking for some sort of dust collection. I have a router in a table, hand held router, table saw, compound sliding miter saw, orbital sanders, jointer, planer, drill press and a table top band saw. I am not sure that I could fit a big dust collector in my shop right now I might be able to find room for a "portable/wall hanging" unit. What are my option? For the planer I haven't got it yet but it is ordered and it is a 735x could I just make a short piece of tubing or pipe right in to a trash can? Does it move the chips good enough for a couple of feet? I am open to all options.
Wait until you get the 735 and run a board thru it. You'll be amazed at how far that thing throws the chips. RichardA has a pic of his dc using the 735 in here recently.
If you can't find it, I'm sure he'll be glad to post it again. You're gonna love that thing by the way!
I love my 735.  The chip ejection works really well - I have my DC connected to it, and even without turning on the DC most everything gets collected anyways.
How about a little more info - do you actually park in your garage shop?  Does everything need to be mobile or easy to break down?
We'll just got the call and my 735 is in, can't wait to use it. I do not park in it any more,I don't have room. My work bench is an old wood shop work bench from a middle school so that takes up a good amount of room plus I have three floor standing shelf units.
I've seen some neat looking "old school workbenches".
I'm working out of a 2 car garage shop, though it sounds like there is a tad bit more breathing room in mine.  I have the HF 2hp collector mounted in the corner on the wall with a thein baffle and trash can right below it.  Shelf is built over the top to store boxes and stuff.  Have one of Rocklers expandable hoses that I switch from tool to tool as I use it.
It works fine, takes up about a 2x2 section of the corner of my garage.
In general, anything with a small dust port on it will probably be serviced with a shop vac - router, sander, table top band saw, miter saw. Most drill presses don't have a dc port but expect to use your shop vac there too somehow. A shop vac can go almost anywhere.
The larger tools really require a "real" dust collector because of the airflow needed - table saw, jointer, planer. This is where it gets interesting - you can get a small one and just move the hose tool-to-tool as needed, but people manage to collect multiple tools,using blast gates to control where the air flow goes. Along the lines of RE's post, most of the "portable" ones (usually 2HP or less, single stage) can easily tuck into a corner. Many people have them in small shops.
Even with dust collection, I still recommend a good respirator so you avoid breathing in any fine dust that still gets in the air.
Hello All,
   The 735will throw chips at least 10 feet... here's proof.
post-15288-0-00997400-1421885164_thumb.j
Cool, I am planning on running maybe PVC pipe in to a trash can and that will take care of that. I already use a small shop vac for the little stuff. I am really looking for a solution for the table saw and jointer, right now I use it and then vacuum everything up with my large shop vac.
Hey Resident is there any chance I could get a picture of your setup. I might be able to find enough room for something like that.
Sure.  I'll snap a pick when I get home tonight and post it up.
Edit:  here you go.  Just ignore all the....dust.  Wait, doesn't that mean it's doing its job?  Ok, I'll go with that.  Same with all the duct tape.
So I measured the approx size of the box and its about 2' x 3', but I could have made it a bit tighter and got to 2' x 2'.  It ducts to the outside, so there is no cannister filter or the crappy bag filter it came with.  That saves me a lot of space as well.  And I get next to zero dust outside where it vents.  The Thein baffle catches almost everything dust/chip wise.
post-15981-0-12346800-1421980532_thumb.j
