Sealing wood and tannin chemistry with baking soda?
Hello all,
I'm not only new to this forum, but also to wood working (of any sort, in all forms).
My wife and I bought a new home (Victorian Style) and all of the porch brackets and corbels have rotted beyond repair. I have a bit of Yellow Pine on hand, but I've read that it isn't ideal for outdoor use (tannins bleed threw, disrupt the sealer/primer and paint, and then it rots quickly).
From what I've read, if you use pine outside, it should work ok if it's sealed well. This is where my crazy question originates... While I have chosen to use the yellow pine I have on hand, and intend to seal it well, would I get a better life out of it if I where to treat it with a chemical stain that reacted with the tannins FIRST, before priming and sealing?
My thought and question, as silly as it may be, is simply; if the tannins are what create problems, chemically nuetralizing them before sealing/priming would be best when being cheap? :-)
Thanks,
(P.S.) I don't expect the brackets or corbels I've made to last for a long time; using my basic patterns I can cut them out rather quickly so replacements really are not an issue.
I'm not quite sure tannins in the pine is the issue. Pines tend to be sappy and have knots. So you need a good primer that will block and seal that in. Check with your paint supplier and they will recommend a good primer for your pine.
-Ace-
If your planing on using a wood stain and a spar varnish? I would suggest a better wood such as an oak for outdoor.
Tannins in cedar yes, in yellow pine not so much. Most pressure treated lumber is yellow pine. Prime all sides carefully, twice !
Yeah, pine doesn't have much tannins, and I've never heard of tannins disrupting a finish either. Oak is notorious for heavy tannin content and it finishes just fine. Woods with heavy tannins can cause iron and carbon steel fasteners to rust prematurely, but that's not a finish issue.
As the others said, prime carefully and it should be fine. Anywhere there is sap or knots try to clean up with acetone and consider covering with shellac before continuing your finishing steps. Note that shellac isn't a good outdoor finish by itself, but it seals better than just about anything and can be covered with exterior paint or whatever. At least one brand of primer contains it for just that reason, though I don't know if that stuff is suitable for outdoor projects.
Other thing to consider is maintenance. You'll likely have to sand and repaint every year.
  • 26,012 Total Members
  • JAR Newest Member ·
